Toshiba Satelite Pro. Screen went black while on internet. Restarted and it says GNU GRUB version 1.97 beta 4 Minimal bash like line editing is supported. For the word tab lists possible comand completions. Anywhere else tab lists possible device file completions. SH: GRUB ..prompt What does this mean? Windows 7 is the operating system. What is the problem?
  • 1 more comment
  • kpearson927 Apr 27, 2010
    Hello thankyou for your quick response. I'm not familiar with computers on your level how can I fix this problem or can I fix this problem in laymens terms?
    How do I boot the computer with partition where windows is installed?
    Can I repair myself
  • 560 Answers
GNU GRUB is the boot loader of Linux. It looks like your laptop is on dual booh and the boot loader which is GRUB was damaged. Do you have another computer that has Linux in it? You can slave your Toshiba harddrive on another computer with Linux and fix GRUB boot loader from there.
Posted on Apr 27, 2010
  • Liza Halbrook
    Liza Halbrook Apr 27, 2010
    Yes, you can fix that but I would suggest to communicate using any chat client so I can walk you through the process. I am going out for a while and will be back after an hour. I am willing to walk you through the repair process. Just let me know.
  • 4,281 Answers
This error comes when there is os system on computere linux and when your computer don't find linuv bootable files.
For that you need to boot your computer with partition where win7 installed or remove ubuntu source from computer.
Let me know if you need further assistance.
Thanks for using FixYa.
  • Yes you can but for that you need windows disk .
    First you have to wiped out the partition where linux grub installed.
    You can delete linux partitionj with linux bootable disk.
    Then insert windows disk into rom then set first boot device as your cd.dvd rom in bios.
    Then it boot with that disk Then follow the procedure on screen and choose R for repair previous windows.
How do i get to recovery mode for ubuntu?
  1. Switch on your computer.
  2. Wait until the BIOS has finished loading, or has almost finished. (During this time you will probably see a logo of your computer manufacturer.)
  3. Quickly press and hold the Shift key, which will bring up the GNU GRUB menu. (If you see the Ubuntu logo, you've missed the point where you can enter the GRUB menu.)
  4. Select the line which starts with "Advanced options".
  5. Select the line ending with "(recovery mode)", probably the second line, something like: Ubuntu GNU/Linux, with Linux 3.8.0-26-generic (recovery mode)
  6. Press Return and your machine will begin the boot process.
  7. After a few moments, your workstation should display a menu with a number of options. One of the options (you may need to scroll down to the bottom of the list) will be "Drop to root shell prompt". Press Return with this option highlighted.
  8. The root partition is mounted read-only. To mount it read/write, enter the command
    mount -o remount,rw /
  9. If you have /home, /boot, /tmp, or any other mount point on a separate partition, you can mount them with the command
    mount --all (This must be done following step 8 so that /etc/mtab is writable.) Alternatively, you could try selecting "Enable networking" in step 7, though this has been found to cause the system to hang (see https://bugs.launchpad.net/ubuntu/+source/friendly-recovery/+bug/981792).
NOTE 1: If you have Ubuntu Quantal (12.10) or earlier, omit step 4 (the recovery mode menu items are displayed on the top-level menu).
NOTE 2: If you reboot, there is no need to hold the Shift key in step 3. The GNU GRUB menu will continue to be displayed automatically on each boot until a normal startup of Ubuntu completes. To configure GRUB so the menu is always displayed, even after a normal startup, see https://help.ubuntu.com/community/Grub2/Setup.
Oct 16, 2013 | Compaq Computers & Internet
What is GNU grub?
The Grand Unified Bootloader (GRUB for short) is a program developed by the GNU software foundation. This program allows your Windows machine to load a number of different operating systems by presenting the user with a choice when the machine boots. This allows you, for example, to have both Linux and Windows XP installed on the same machine. If you find that you need to restore your XP system to a previous state and want to remove GRUB from your Windows XP, the process can be done in just a few minutes.
Ensure that your computer can boot from the CD/DVD drive. Start your computer and watch the startup screen. It will flash the key combination you need to press to enter BIOS. Enter this key combination and go into the system BIOS. Look under "Boot Options" or "Boot Order". Select "Boot from CD/DVD Drive" and make sure that it is listed as the first in the boot order. Save your changes before you exit the BIOS. Open the CD/DVD drive and insert your Windows XP install DVD. Reboot your system. Press "R" for "Recovery Console" when the "Welcome to Setup" screen appears. Enter the administrator password. At the prompt, type the following command: fixmbr Allow the XP system to recover the boot sector. When finished, it will return you to the command prompt. Type:exit Reboot your XP system. Hope this helps.
Dec 30, 2012 | Computers & Internet
Toshiba Satelite Pro L300 won't boot up properly.
firsly start your computer in safe mode then do syatem restore .if problem will not solve then mail me at vicky.akon11@gmail.com
Jun 26, 2010 | Toshiba Satellite Pro L300 Notebook
Hi,toshiba satelite pro L20 beeps when start up
Run check disk for hard drive errors. I recommend immediately backing up all your data that you can, wiping it, and reinstalling your programs. The rebooting problem smells like a bad hard drive. I just went through it with a Compaq at work.
Sep 16, 2009 | Toshiba Satellite Pro 6000 Notebook
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
Black screen
use the same key combination once again it will give you your display back...
Dec 02, 2008 | Toshiba Satellite A105 Notebook
My laptop wont boot
How long does the screen display that quote? Sometimes Linux will lock up completely at boot, but usually it will give a message such as "kernal panic" if it does; in your case, if the GRUB boot-loader is failing to find a kernal to boot, you may not have a valid boot-loader configuration file or installed operating system. Or, you may just need patience.
I suggest you try booting from a Live distro disc, such as Ubuntu (DVD), SuSE (DVD), or Damn Small Linux (this is probably the fastest, at only 50 MB) or DSL's Not Damn Small Linux (CD) which still has pretty minimal hardware requirements but includes more tools. Even DSL should let you view the files on your laptop's hard-disk drive and edit configuration files if there are issues.
Jul 30, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
