I have a split system air conditioner that spews water whenever we turn it on. How would we go about fixing this issue? Seems the drainage isn't working right. The air conditioner is a Fujitsu.
  • 360 Answers
Wwwwwww
Posted on May 11, 2010
  • Quadri Olatunbosun
    Quadri Olatunbosun May 11, 2010
    its not that the drainage is not working, but I think it should be leaking. Open up the air conditioner, gain access to the drainage, and seal up where it is leaking and that's all.
    Take care.
  • Madn3zz May 12, 2010
    Thanks for the reply. Would you have any take apart instructions for this? The last time the air conditioner guy came by for the same problem, he said that our drainage was clogged.
    A good amount of water does come out of the air conditioner.....
Water coming out of lg ac
Your unit will have an external vented drain, check to make sure this is not blocked with fluff or dirt as this will cause your issue.
Mar 04, 2012 | LG LSC121PMA Split System Air Conditioner
Hello! I'm having some difficulty finding the drainage on this specific model. It's in my husband and I's bedroom....for the last two mornings we have found a puddle on the floor in front of...
Water leakages out the front are usually attributed to poor drainage. IE , the wall unit is not sloping slightly to the rear, or in the case of a split system, the drain hose is not directed down and away from inside. I would suggets checking the filters first. If the filters are blocked, and the cooling is set really low, its possible for the coil to start freezing and thus, leak water out the front. If the filters are clean and the coil is still freezing, you may have a gas shortage . Eventually when the gas runs out, the water leak will stop and the unit wont cool at all. If the system is working properly, on cooling mode, there should be cold air inside and the unit should be blowing hot air outside. If on heating mode, the reverse happens...
Jun 14, 2011 | General Electric AST05LK Thru-Wall/Window...
My 3-year old LG air-conditioner was leaking water. So i called some 'experts' to come fix it. This is the first time I called for maintenance service on the air conditioner. The 'experts' dismantled some...
White snow.. I had this issue when 2 inside unit electrical lines were hooked up backwards at the compressor. The compressor would pump too often and overcool the inside unit, because it was using the wrong temperature sensor. But you could have a different issue. I'd have them recheck your freon levels, that can cause it to cool too much - should be 120-135psi when it is running, after 5-10 minutes or so. They adjust this for the outside temperature though.
Oct 04, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Oct 11, 2009 | Windchaser Portable Air Conditioner
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Mold goodman phkj048-1
3 places where water could be coming from, The Ground, The venting system or the Condensate. Eliminate each one by first checking the condensate piping and check to make sure it is draining to the drain. Blow thru all hoses to make sure they are not blocked. Secondly, spray with a garden hose the venting system to see if the water is entering the system thru the venting. Lastly, if this happens only when it rains, you could have a ground water drainage issue.
Dec 26, 2007 | Goodman PHKJ048-1 Air Conditioner
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
