Question about Toshiba 57HX81 57" Rear Projection Television
I have a toshiba model 57hdx82. It has a shadowy
I have a toshiba model 57hdx82. It has a shadowy sort of multiple immage problem. After it sat for a couple of days (unpowered) it worked clearly for about 45 min then went back to the shadow... Someone thought it was the control board. Would replacing capacitors or other small parts on the control board solve the problem?
Thanks,
Marlyn
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
You have a cinversion problem you can purchase kits and do it yourself or send it in to be done average cost og repair 280-320
Posted on Apr 27, 2010
First doesn't turn on, now it does but have NO immages, just sound
I would expect that the bulb has failed.
Toshiba DLP Replacement Lamp Toshiba DLP Bulb Part 1
If you decide to replace bulb I suggest that you replace with the best quality bulb. I found the brightness between good and best bulb was significant. I have ordered from the internet and have had great results.
There are other possible causes of lost video. The bulb is only the most likely.
Good Luck
Jan 29, 2013 | Toshiba 53HX71 53" Rear Projection...
Why is my Toshiba flat screen showing this red haze on screen?
Try adjusting the settings, You didn\'t supply the Model? Connected to Cable? Sat? Have you contacted your Provider? I can\'t tell much from the video ,Is it "pixels"? Sometimes my toshiba will freeze or become pixelated, it\'s the signal from Xfinity. Pull the plug on the TV cable/sat box wait 30 seconds ,plug in, saame with TV. A sort of reboot. Reset your setting to default. Satrt from the beginning of setup. Is it under warranty? Maybe you should be watching the Outback Bowl,
Jan 01, 2013 | Televison & Video
57hdx82 no picture poping sound when I turn on set
sounds like either a power supply or High voltage circuit problem and not likely a do it yourself repair
Mar 11, 2012 | Toshiba 57HDX82 57" Rear Projection HDTV
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
Replacing protetive tv screen
replacing is easy. finding the part is difficult. I have been searching for the screen for my 50" Toshiba for 6 months.
Dec 21, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Loss of sound when I go to HD mode of tv.
Unplug the Moto box and plug back in after 1 min, as far as the codes, which remote cable/ tv? Cable remotes vary so much you will probably have to call your provider to have them walk you through programming.
Jul 16, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Black out ?
There could be bad solder connections on C809 and C810. There was a technical bulliten on this problem a while back agao. good luck
Apr 29, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Sony model kv-L34sn11
Send a picture of the screem, the way you explain we can't help.
Aug 30, 2006 | Sony KV-32S26 32" TV
Toshiba 57HX81 57" Rear Projection Television Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
