Question about Belkin F5D7234-4 Router
Just installed Win-7 router driver is missing I think My router is not detected checked all connection all are ok
    President:
  • 1,768 Answers
1 Try running the software in Vista mode.
2. Go to the manufactures web site and check for firmware updates for the router.
3. the router should connect without upgrade when hard wired via the Ethernet cord.
4. you didn't designate if you are truing to connect wirelessly or via the RJ45 cord.
Posted on Apr 27, 2010
Tip
Windows 7 Drivers for Printers and other accessories
As it is known to everyone that Win 7 is the latest Operating System from Microsoft and that lacks one of the best thing which Windows XP was having embedded inside it. Yes the in-built drivers which were automatically detected and installed without any rush for chasing drivers. Till date there are many computer peripherals like (printers, scanners, webcams, tablets, sound cards, NIC or Ethernet or LAN card, laptop, notepad GPS devises, Routers, Switches, Modems, Mobiles and many more) for which MS has not yet released the drivers or the publisher has not yet released drivers for Win 7. Hence,ultimately the user is suffering as they cannot use the peripherals which they were able to use with XP but after installing Win7 those devices don't work anymore because of the lack of drivers inside Win7 Operating
System.
The good news
Win 7 has a very good feature inbuilt on this problem that is compatibility driver installation mode. One can try and install the existing Win XP driver in Win7 with compatible mode. If an XP driver is installed in Win7 with compatibility mode then that particular peripheral gives out the efficiency upto 90% .
In order to install the driver first connect the device to pc and then select have disc in the wizard which pop-ups and then follow the wizard and look out for the word compatibility mode. Just select compatibility mode and your device isready to be used in Win 7. Otherwise you can also install the driver through control panel add new hardware and simply select have disc instead of search automatic and don't forget to select compatible mode while following the wizards instructions.
on May 03, 2010 | Computers & Internet
Dane elec portable hard drive not recognised by win 7 pc
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted.
If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off."
Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive.
Connect the cord directly into an outlet and power up the drive.
If the drive is powered and still not working, check the data cable.
Power down the hard drive and disconnect the data cable from the computer.
Wait 30 seconds to one minute.
Reconnect the data cable and power up the drive.
If the drive is not detected, power down the hard drive and connect the cable to a different port.
Power up the drive.
If the drive is detected but not working, check for a missing driver.
Click on the "Start" button, right-click "Computer" and select "Manage."
Enter your administrator password if requested.
Select "Device Manager" and double-click "Disk Drives."
Right-click the yellow exclamation point and install the missing driver. Close the Device Manager.
If the drive is detected but not working check to ensure it has an assigned drive letter.
Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer.
Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested.
Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add."
Assign a drive letter.
Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window.
If the drive is detected but not working, check whether the drive is in sleep mode.
Click the "Start" button, right-click "Computer" and select "Manage."
Select "Device Manager" and double-click "Universal Serial Bus Controllers."
Double-click the first instance of "USB Root Hub" or "Root Hub."
Check for the hard drive.
If the drive is not visible, move to the next instance of "USB Root Hub."
Continue checking each instance until the hard drive is located.
Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager.
Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
Could not detect LAN connection after reinstalled win 7, same os as before
Hello and Welcome to FixYa!
Make sure, that the ethernet driver is properly installed and is Working. Moreover, do make sure, that the ethernet (LAN) is enabled, from the Control Panel Network Connections. Secondly, double check that the LAN is not disabled from the BIOS settings (Settings at the start up menu, before the OS boots).
Concerned.
Aug 11, 2011 | Computers & Internet
I have a wpsm54g successfully connected to my router and 2 XP laptops that can print via the print server. A friend has a win 7 laptop that we want to connect to the print server but the linksys install...
go into the control panel and add a wireless printer, it should detect it on the network.
if this doesnt work try going on the website and locate the driver
Mar 06, 2011 | Linksys WPSM54G Print Server
I have Vista OS on my laptop & have never been able to get automatic updates to work. I have had nothing but problems with this OS & want to instal Win 7 but I am told I can't do that until I see...
Don't worry about "compatibility" issues. You can pretty much force Win 7 onto just about any laptop.
What you need to do is backup your files (that is if you have any you want saved)
You need to do a CLEAN install, not the UPGRADE when you boot from the Windows 7 cd.
Delete ALL of the partitions...then hit NEXT.
When it's done installing, run the updates and if you're missing any drivers after the updates post back the model of your laptop / desktop and we'll help you patch the missing ones.
Best of luck!
Jan 02, 2011 | Microsoft Computers & Internet
Usb broadband mc760 modem works fine on computer, bought zoom 4501 wireless router followed win 7 set up instructions windows sees the router comunacations ok between computer ans router the...
Welcome to Fixya
Hi. As what i understand the MC760 alone can connect to the internet without connecting to the router. This device will act as a modem right away. This is the one of the device where you will put in a simcard to connect to the internet if i am not mistaken. You need to download and install the software of for this device and creat a dial up for your to be able to connect to the internet. Here's the link where you can download the driver and the procedure on how to create Dial up.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 03, 2010 | Zoom (56600000) Router
Why is my ethernet driver missing ? where can i get an update done from ?
Well, there are a lot of reasons to cause your driver missing or outdated.
As to the solution, I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Nov 16, 2010 | NEC 82559-based Fast Ethernet Adapter
Qualcomm cdma msm tataindicom driver missing in Windows 7
Hey, there
Best regards!
Sep 15, 2009 | Computers & Internet
Belkin F5D7234-4 Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
