Question about Phoenix Digital PD-VIVID 7 in. Car Monitor
P-d-s visor
This part of an old system i had till itraded the car in it worked. the new vechicle dodge 2005 has a factory dvd player plaer an screen, tried to add visor screen pds cable which is close to( s video) to audio vid jack an power pos, an ground connections. an all i get is a blue screen. do i need anything else or is the factory system not compatible with the visor
I just tryed to hook my cd plaer to my car and the dvd plaer wont work the brake wirer needs to be hooked up but i dont know how to do that
what you need to do is to get the green wire from unit and hook it up to a toggle switch with only on/off then you would connect the green to toggle switch and the rest of the connections on toggle switch ground them. flick it slowly twice and the dvd should show even when driving. just remember its against law so if you see police switch it off quickly
Oct 17, 2010 | Clarion MAX385VD Car DVD Player
I just purchased a used 2000 Ford windstar. It is missing the TV screen. What kind of TV screen do I buy for it. The VCR is placed in the trunk with a remote to work it but the TV holder doesn't drop...
That is a tricky question. It would depend alot the audio9 system that was running the video. If it is factory u will have to run the factory video, if it was installed aftermarket as an add on u can install just about any aftermarket video you want to put in. If you have a seperate dvd player and it does not say ford you had an aftermarket video, if you have no dvd you more than likey had an aftermarket system, you will more than likey have to take your vechicle to a stereo shop and they can tell you if it is factory or not.
Jul 30, 2010 | Car Audio & Video
Need replacement headphones for my dvd system 2005 grand caravan
bought mine from KOSS. Work great. I have the Koss factory here in milwaukee so just went to the outlet store. otherwise probably available by internet.
Jul 28, 2010 | 2005 Dodge Grand Caravan
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
Reset ''Service Vehicle'' message in 2005 Dodge Caravan
WHEN SERVICE VECHICLE LIGHT COME ON.THE DEALERSHIP HAS TO CHECK OUT EMISSION CONTROL SYSTEM.MAKE SURE ALL EMISSION COMPONENTS IS WORKING PROPERLY.THEN THEY HAVE TO RESET SERVICE VECHICLE LIGHT WITH A SPECIAL SCANNER.
Oct 16, 2009 | 2005 Dodge Grand Caravan
Rechargeable Battery Pack
I need help for my DVD plaer. The battery pack is not charging. Help. Help.
Aug 02, 2008 | Protron PDV-228 Portable DVD Player
How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Apr 26, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Phoenix Digital PD-VIVID 7 in. Car Monitor Logo
51 people viewed this question
Top Phoenix Digital Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phoenix Digital Car Audio and Video Expert? Answer questions, earn points and help others
