I want to connect my new laptop wirelessly to use the Virgin Broadband setup on my (uncle's) computer.Does cable media require a different tyye of router to othres? Can you advise what kind of router should I look for, preferably a relatively inexpensive one.
  • clarenicolas Apr 27, 2010
    Does this router work with cable?
    What is a WEP code?
    Does this work with cable?
    What is a WEP code?
  • 4,281 Answers
Linksys WRT54G is best router for use internet wireless.
You can check it's configuration below.
click here
Then You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Apr 27, 2010
  • Yes it worked with ethernet lan cable too.
    WEP code means if you want to secure your wi fi you need to enable WEP security then you can add password there.
    Then only those users can connect with your wifi wh know that wep code.
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Cannot finish connecting
Hi fozzy211 - Please don't rate this 'til were finished. You've got two things going on. You said it's telling you to check the cables and then you say it's saying the router isn't from Verizon. Is it both? Are the cables hooked up correctly to your knowledge? We can fool Verizon's system. Let me know if you actually have two problems. For now I would only hook up one pc via wired until it's working. I'll await your response. Thanks.
Jeff
Jun 04, 2008 | NetGear WGR614 Wireless Router
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
ISP
I have a feeling I might be able to find the router setup information if you can tell me the correct answer to the prompts needing answered by this link
Virgin Media Broadband Help
The model number of the Belkin router may be of interest if detailed configuration instructions are required and because there is the a report of an issue with a specific belkin router model on the Virgin Media site that appears to require a firmware update to work well with that particular internet service.
Dec 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
