Question about HP OfficeJet D135 All-In-One InkJet Printer
When u relplace say the black side do you have to do the color side if its empty to make it work
  • 150 Answers
You must have both black and color cartridges in the working condition. They don't have to be full but must show dome ink. Steven 818-888-0006
Posted on Apr 27, 2010
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
Can I print in only black if one of my color ink cartridges is empty?
Yes, you can! You just need to paint your empty cartridge with a black sharpie, one of the side of the cartridge that points out of the printer where you can see ink level.
Or, get a black tape and stick a piece inside of the empty space in the cartridge slot without the cartridge. Again it's a narrow vertical side closest to the edge.4c8b63e.jpg
It will be seen by the sensor as the cartridge is not empty.
Sep 11, 2010 | Brother MFC 420CN All-In-One InkJet...
Why my color catdrige is empty faster than black
just change your settings to print in only black and white and it will print just fine. there should be a button on the top of your printer that says print black and white or grey scale , its a common problem .,if you see next time it should work good .(its actually making the black color using the colored catridge by mixing the three colors in diffent ratio.)
Mar 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
How do i replace cartridge
On the right hand side of your machine-FRONT-right there is a panel that should have come with a sticker on it, you may have taken the sticker off so anyway, it is the ONLY panel on the front right side it just pulls down, put your finger on the rigth side of the machine yhou will feel a little indent and then pull it down, and there are your four ink cartridges. Each cartridge must be replaced individually and on the bottom of the panel you pulled down it will be labeled (B for Black, Y for Yellow, C for Cyan and M for Magenta, and each print cartrdige should also be colored to make it easier as well). Anyhow, you pull the little plastic purple tab that is covering each ink cartridge (in the machine) forward towards you and it should release the cartridge for you to pull out and dispose of) every now and then I have a little trouble and need to use something to help me get started pulling a cartridge forward-just like the tip of a pen or something but you should have no problem with this, and then you put the new cartridge in-the way it says-there should be an arrow on it showing you which way to put it in (also look as you pull the old one out) and as you push the new one in, the plastic tab will click shut and you will hear a "'spray sound". When you are done, close the cover and the machine will first do a "cleaning" before it is ready to be used again. Here is a tip for you as well, this machine WILL NOT WORK if you have any empty ink cartridges, they ALL must have some ink in them for you to print anything, even if you just want to use black, you have to color cartridges as well, I try to use every last bit of color before replacing a cartrdige, I wait until IT MAKES ME REPLACE IT by saying "empty black cartrdige" before I replace it "near empty" is NOT ENOUGH to replace it, mine has been saying "near empty magenta" for weeks now and it still works fine, it just wants me to replace with a new one and waste more money as this ink IS VERY EXPENSIVE, it cost me over $75 to replace all four ink cartridges, the best deal is to get the combo pack with all the colors, or the one with the three colors and then the double black pack. some colors will obviously get used quicker than other colors, so like I said, I have been waiting to replace that "near empty magenta" UNTIL I HAVE TO, as it hs been telling me to do so for weeks now, and I have a replacment in the drawer but once I replace it, it is like throwing money in the garbage since the one that is near empty, is FINE sitting in there while I PRINT OUT BLACK AND WHITE COPIES most of the time anyway, it just won't let you print if ANY of the cartrdiges are ACTUALLY EMPTY, even if you are not using that color, you still cannot have an empty cartrdige or NO cartridge in the machine, it just WIL NOT WORK. GOOD LUCK.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Jun 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
52 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
