Question about Sony DAV-FX100W System
Sony DAV-FX100 replace wireless with wired for rear two speakers?
I have a Sony DAV-FX100 "Dream" (nightmare) System that no longer has a functioning IR Receiver/amp for the rear two speakers. Is it possible to hardwire directly?
5 Suggested Answers
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
Posted on Oct 11, 2008
welcomejee
  • 10594 Answers
SOURCE: sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Posted on Feb 05, 2009
SOURCE: S-Sir Sub Unit won't pair
In order to properly pair the units, verify that the channel switch on the back of the sub units are set to either A, B, or C. Then go into the setup menu and go to setup tab. You can then scroll down to system setup. Verify that the base unit is set to the same channel as your sub units A, B, or C. You then can choose the pairing operation. Have your sub units close to the base and on for this operation. They must be linked to have the pairing operation work. The pairing option will ask if you are ready to pair a sub unit. Select OK. You will then be instructed to begin pairing. Find the pairing button on the back of the sub unit and depress. Depending on the sub unit you may see a red light flash or the front display will say pairing. Once complete the menu screen on the TV will tell you that the pairing is complete and ask if you would like to do another unit. Continue if you have another unit or select OK to complete the process. Once you return to the system setup menu the channel indicator A, B or C will have the work pairing next to it (i.e A (pairing)). If you continue to have trouble you can change the RF channel on the system setup menu from AUTO to ON. Good Luck. CEB
Posted on Mar 22, 2009
  • 42 Answers
SOURCE: I HAVE THE SONY DREAM
yes, but you will need an adapter to do so I believe. You will need a 1/8 in headphone to component audio plug (headphone to the white and red colored plugs), they are pretty easy to find. The headphone end goes to the laptop and the white and red plugs go to the back of the receiver. Note where you plug them in, either above or below the jacks you use should be the component they will be recognized as (Video 1, 2, AUX, etc.)
If there is an AUX pair of jacks, use that one, otherwise just pick one that is open and plug into those. Now with the remote select whichever component was associated with the plugs you used on the back of the receiver and you should be good to go.
Posted on Jun 02, 2011
How to fix push power protector Sony DAV-DZ870W
try disconnecting all speaker wires from the main unit, then turn it on. If it still goes into protect - then the amp is blown and you need to replace the main board.
Jul 13, 2014 | Sony DAV-DZ870W Wireless Home Theater...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
NEED LONGER SPEAKER WIRES- IS IT POSSIBLE TO ORDER
Yes you can goto www.Bogue-Engineering.com
and they will make custom length cables with the special connectors for you.
Jan 03, 2010 | Sony DAV-DX255 System
Sony universal remote will not operate sony dream system
Feb 05, 2009 | Sony DAV-FR10W System
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Dream System DAV-DZ120
Go to http;//audio.manualsonline.com maybe there you find the answer.Good luck
Jul 03, 2008 | Sony Dream Home Theater System, DAV-DZ120...
Blinking standby light system will not turn on
I was having a similar problem and determined that there was a short in the speaker leads for the center channel speaker. The leads to the speaker were touching, after being moved, slightly while housecleaning. Once short was eliminated, unit powered on and worked with no problem.
Oct 21, 2007 | Sony DAV-C770 System
Sony DAV-FX100W System Logo
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
