Question about Epson Stylus Photo R200 InkJet Printer
Hi my epson printer r200 is printing nothing iv just installed cartages and it just prints blank no coulers nothing
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
here is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
My epson r200 won't print pdf's anymore. It will print word and png files but not pdf.What's up?
my epson printer wont print iv put brand new inks in it it prints nothing but blank paper
Apr 14, 2010 | Epson Stylus Photo R260 InkJet Printer
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
ESPON Stylus Photo R200 Ink Status Problem
The epson like many other brands actually uses a small amount of the coloured ink in order to give the black print a more polished look.
You must use your printers properties page to set printing mode to Greyscale if you don't want it to use the colours.
To do this go into your control panel, open the printers icon, and select your printer, right-click on it and select Properties from the grey menu.
You will have to look through the pages and find the setting or check box for Grayscale. When you find it, select it, then click ok at the bottom of the page. This will stop the printer from using coloured inks to tone the black print.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Epson Stylus Photo R200 InkJet Printer
Hi, i have an epson R200. ink levels are all fine. it goes to print and goes through alkl the actions but paper comes out blank? can you help
I have the same problem ... ink is full (New) but won't print, although it seems to think it is printing. I've gone through the clean process, but no result.
Jan 23, 2009 | Epson Stylus Photo R200 InkJet Printer
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Print CD update needed
LINK to print cd mac version 1.6aE (it's Epsons Russian website, don't worry - the software is in English!)
not sure if it suits R200 if not then
see my other post here for more info
Jan 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Black ink
I had a similar problem with the r320 epson
I found that it had blocked.
this works well to clear the head
1 switch on the printer with the cover open
2 as the cartridge head moves away from its docked position pull the mains plug.
3it is then possible to slide the head to the left .
4 there is a square of flet on the right the head would normally be over, add a squirt of mr muscle bathroom cleaner on the pad ( main off)
5plug the printer back in and the head will return the the docked position.
6 leave for and hour or 6 then try to print
Dec 03, 2007 | Epson Stylus Photo R200 InkJet Printer
Colors print, but not the black!
that same thing happen to me try to wipe the needle that the ink is on with baby wipes.
Nov 27, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
