Question about IBM ThinkPad 380ED
Error When i switch on error 161/163 comes up, click on 'ok' and an icorrect date and time appear but correcting them makes no difference.
RESOLVED same problem. removed both batteries (cmos and computer) set time and date, rebooted holding f1 key. this got me into setup where i ran system test. reset my boot as floppy, cd rom, hard drive. used win 98 boot to check dos and c:\ drive. found no errors and rebooted. win98 started with no errors reported. RESOLVED BY TERRY LATOUF OWNER OF UNIVERSITY COMPUTER SERVICES WACO TEXAS. PHONE SUPPORT AT 254-753-0284
Posted on Apr 05, 2008
  • Anonymous Apr 05, 2008
    RESOLVED
    same problem. removed both batteries (cmos and computer) (BATTERY LOCATED UNDER PANEL WITH DOUBLE SCREWS ABOVE RAM) set time and
    ERROR ON LAST POST
    remove cmos battery (under panel with SINGLE screw) and reset time and date. keep power to unit until the battery is replaced (or keep resetting time and date). Sorry for the confusion but did not realize the error until reassembled and restarted. RESOLVED BY TERRY LATOUF OWNER OF
    Genius:
  • 1,554 Answers
Sounds like your cmos 3 volt battery is dead and needs replaced.
its a very small coin size battery located/hidden inside the laptop.
you will have to google the placement or just find it.
Posted on Apr 02, 2008
SOURCE:
What is the solution to error code 0x80072f8f which occured during window activation?
Try this one.
  1. Click the Start Collapse this image Expand this imagevistastartbutton.jpg, type timedate.cpl in the Start Search box, and then click Timedate.cpl on the programs list.
  2. On the Date and Time tab, make sure that the computer's date and time are correct. If the settings are incorrect, click Change date and time.
    Collapse this image Expand this imagesecurityshield.jpgIf you are prompted for an administrator password or confirmation, type the password, or provide confirmation.
  3. In the Date and Time dialog box, use the following procedures:
    • To change the date
      Under Date, click the left or right arrows to find the current month in the calendar, and then click the current date.
    • To change the time
      Under Time, double-click the hour, minutes, or seconds that you want to change, and then click the arrows to increase or decrease the value.
  4. When you finish changing the date and time settings, click OK.
  5. Try to install updates again.
May 20, 2011 | Microsoft Windows Vista Ultimate Edition
How do I set the date?
Follow the instructions below to set date and time on your printer.
  1. On the product control panel, press Setup (c01715732.gif ).
  2. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Basic Setting , and then press OK .
  3. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Date and Time , and then press OK .
  4. After Enter date appears on the control panel display, use the keypad on the control panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10). After entering the date, press OK .
  5. After Enter time appears on the control panel display, use the keypad on the control panel to type the time in the correct two-digit format, HH:MM (10:15), and then press the Right (c01185072.jpg ) Arrow button to switch between AM and PM . After entering the time, press OK .
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
Blocked by internet explorer 8
There is an easy way to fix it.
Make sure your date, time and year is correct on your PC, problem solved..... good luck :-)
Apr 13, 2010 | Yahoo Mail
I have several 600's and they all have the same issue. They are giving 161 192 163 errors. I replaced the battery in them and then go to try and setup the time. However, instead of letting me set the...
161 = CMOS configuration lost (battery has died).
163 = CMOS error; Clock is not updating.
192 = System fan is faulty, not plugged into the system board or the system board itself is faulty.
Whe you replaced the RTC (real time clock/BIOS battery) did you make sure that the CPU fan was working?
If it is then go back into the BIOS and reset it to defaults. Save the changes and reboot, then go back into the BIOS and try to set the time and date.
Regards.
Feb 22, 2010 | IBM ThinkPad 600 Notebook
Xerox 6110 24h error
1. Press Menu until System Setup appears on the bottom line of the display and press OK.
2. Press OK when Machine Setup appears.
3. Press the Scroll buttons until Date & Time appears and press OK.
4. Enter the correct time and date using the number keypad.
Month = 01 to 12
Day = 01 to 31
Year = requires four digits
Hour = 01 to 12 (12-hour mode)
00 to 23 (24-hour mode)
Minute = 00 to 59
Note : The date format may differ from country to country
Jul 09, 2009 | Xerox Phaser 6110 All-In-One Laser...
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
C90 epson printer "appears" Cannot be used error
1/ first of all please , don't forget change , date vacate , , date , please ( yes sir ) , ,
2/ begin , adjustment , will go up this window comes to , click already at , Accept ,
3/ , click already at , Perticular adjustment mode ,
4/ click at , Waste ink pad counter , to strip [ zone blue ] , then press , ok ,
5/ already will go up a window , Waste ink pad counter , click at , check , clip_image010.jpg
6/ press , ok ,
7 / click already at , lnitiailzation ,
8/ press , ok ,
9/ last step , press , ok , then close , then open again , only ( yes sir ) , ,
Dec 17, 2008 | Epson AcuLaser C900 Printer
Setting date and time on HP office jet J4580
Set the date and time
    press OK .
    press OK .
  4. After Enter
    date
  5. After Enter
    time
Aug 21, 2008 | HP Office Equipment & Supplies
Ibm 600x errors 173, 163 & 301
Take the battery out and bootup it should work then....
Mar 03, 2008 | IBM ThinkPad 600X Notebook
Keyboard scramble
You have different keyboard layouts installed.
Standard: qwerty, asdfgh
Dvorak: ‘,.pyf, adeuid
To prevent the keyboard from unexpectedly switching up on you, open your control panel, select Regional and Language Options.
In the Regional and Language Options dialog box, click the languages tab, select the details button at the top of the dialog box.
In the Text services and languages dialog box, under installed services: select the Keyboard United States-Dvorak service and then click the remove button, click ok, click ok.
Dec 23, 2007 | EliteGroup P4VMM2 Motherboard
IBM ThinkPad 380ED Logo
163 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
