Question about Frigidaire FEF376 Electric Kitchen Range
NEITHER OVER ELEMENTS WORK MOD#FEF379ACK - Frigidaire FEF376 Electric Kitchen Range
  • Frigidaire Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
How to replace bottom heating element in whirlpool mod-GR563LXSB? this is a floor mod electric stove
In most cases you unplug it from the power, take off the back, locate the wires to the element, remove the connectors and retainer nuts, go to the front and remove the element, replace it in reverse order.
Feb 04, 2017 | Whirlpool Kitchen Ranges
Dryer work but have no heat/kenmore mod:110 70982990
A burned out heating element is the most common cause. Other electrical components are also possible. Check the element first.
Feb 15, 2014 | Kenmore Dryers
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Have a condenser auto 7kg dryer, mod cde107. it doesn't get hot thought it would be the element but the 'empty filter' light keeps flashing even though its clear. if the filter censer was broken would this...
no, it would not sounds to me like your either not getting power to the elements, or they are bad, need to check, power to the unit first, then to elements, when you turn it on finally the elements itself, please be safe if you work on it yourself thks larry
Feb 26, 2010 | Dryers
I have a whirlpool range mod rf368lxpq o replaed probe and panel still very slow to come to temp. pre heat goes to about 200 deg and then veryy slow to come up to temp and hold temp
It sounds like one of the elements are not working. There should be a concealed element in the bottom of the oven and a 'bake assist' element at the top iether seperate from the grill element or as a dual element assembly. Both of these elements should heat on bake function (not the grill element though), check for heat from both by turning bake on and feeling for heat from top and bottom. The oven requires heat from bot to get up to and maintain temp.
Hope this helps
Dec 02, 2009 | Kitchen Ranges
I have a Kenmore Dryer mod. 96281100 which runs but no heat. I tested power input at 240v, thernal fuse closed, thermal hi temp closed, element closed and not grounding, thermostat cut-off closed, and...
If you have 240 VAC across the element, but the element is not heating, then you have a bad element. If you don't have 240 VAC at the element, then work your way back with the voltmeter to find where the voltage is dropping
Nov 11, 2009 | Kenmore Dryers
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
Install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Sep 12, 2009 | GE JTP45 Electric Double Oven
Heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Aug 04, 2009 | Dryers
Moisture sensor does not seem to work
your heating element may be bad if your cycle completely finishes and the clothes aren't dry. If
Jan 28, 2009 | Dryers
Frigidaire FEF376 Electric Kitchen Range Logo
120 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
