Question about HP OfficeJet 6110 All-In-One InkJet Printer
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
    President:
  • 1,768 Answers
Your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Posted on Apr 27, 2010
I cannot receive fax on my dell940 printer. help
The A940 is not a standalone fax machine, and needs to work with your computer to send and receive faxes. Your computer needs a dialup modem installed and a connection to a phone line, and you need to have fax software installed. The printer actually only works as a scanner to input a document to be faxed, and as a printer to display a received fax. The installation CD supplied with the printer has fax software on it you can install, and other software is available online. This document from Dell (the fax section of the user's guide) may be helpful.
Jul 29, 2011 | Office Equipment & Supplies
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I can't recieve fax
The MP500 is not a fax machine. If you want to send and receive faxes using the printer, you need to have a dial-up modem in your computer with a telephone line connected. The computer then needs some kind of fax application like Microsoft Fax, which does the actual sending and receiving. The printer is just used as a scanner when you send, and to print received faxes.
If you have all this connected already and you can't receive, check your incoming telephone line and fax software settings to be sure the line is answering correctly.
Mar 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
I am getting a very precise, dark line down the middle of anything scanned - fax or feeder-copies. Cleaned all available areas & changed toner cartridge without success.
if you have already cleaned all the areas in scanner, then the reason should be an error in your scanner interface cable. This is the flat, grey cable which is connected to scanner lamp. Try to disconnect it and connect it again. When you use your Canon just for printing, there should be no dark lines.
Also maybe you scanner lamp has a problem. These things you can't repair.
Good luck
pifonski
Feb 20, 2011 | Canon LaserBase MF5750 All-In-One Printer
Where to plug in the phone line for the fax
You don't plug a phone line into this printer. It's not a fax machine itself. According to the user's guide (which you can download here), "To send a fax using this printer, you need to have the printer attached to a computer that is equipped with a modem and has Microsoft Fax installed."
What this means is that the printer is just serving as the input (scanner) and output (printer) parts of a stand-alone scanner, but you need your computer to connect to the phone line. Without the computer modem and Microsoft Fax software, your printer is, well, just a printer, with scanning capability.
Sorry! Thanks for using Fixya.
Nov 19, 2010 | Dell 944 All-In-One InkJet Printer
How do i send a fax
Make sure the printer is connected to a computer that is attached to a fax modem. The Lexmark fax software should already be installed in your computer. DSL (digital subscriber line) and cable modems are not supported by the fax software. For the instructions on how to send faxes, refer to the printer's User's Guide. Just click on this link: http://bit.ly/aSItHD. Scroll to Page 26. Thanks.
Aug 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
Can't remember how to connect to fax
I don't see that the Lexmark X3430 functions as a fax machine. It is a combination Printer, Scanner and Copier. If you would like to send faxes, you would need to scan the document using this device and then fax it by way of a separate fax modem installed on your computer, which would need to be plugged into your phone line.
If this is not the right model number, let me know and I'll take a look.
Jun 02, 2009 | Lexmark X340n All-In-One Laser Printer
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x5250 printer scanner and fax all in one and i am trying to use fax part and it is saying no modem detected
You need to have a dial up modem installed on your computer. It is prety cheap and a phone line to connect to the back of the modem.
Dec 08, 2008 | Lexmark X5250 All-In-One InkJet Printer
Fax issues
Thanks for the response! I managed to do this myself,I was not aware that your PC must have a "phone modem" card! Once I installed one I already had on hand, it went flawlessly! Windows XP likes this printer!!! Nice "all in one" printer,for sure. I used the Lexmark to replace our Epson scanner and seperate printer, AND our clunky old fax mach. Thanks for such a helpful website. Regards, Jim
May 30, 2008 | Lexmark Wireless X4850 All-In-One Inkjet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
115 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
