Question about GE DBSR453EBWW Electric Dryer
We overloaded the dryer and now the dryer is making a loud noise
We overloaded the dryer and now the dryer is making a very sharp lloud noise when running. Im wondering if the belt is torn. Im not sure if i should look in to a repair person or if i should do it myself. Please let me know what part is damaged if you know and i will see if its worth my while to do it myself. thanks
    Habit-Forming:
  • 98 Answers
The rear drum bushing or the front drum slides (or both) are probably worn out. You can view the rear drum bushing by removing the small plate in the center of the rear panel. Check if the center pin on the drum is touching the rear drum bushing housing. The rear bushing is made of plastic and is only about 1/16" thick, so look closely. If the loud noise is metal on metal at the rear drum bushing, replace the whole rear bushing assembly (drum center pin, bushing, and housing). Often, the front drum slides also need to be replaced. Check them before you buy the rear bushing. There are two at the bottom front of the drum and four more at the top front of the drum. You'll have to remove the front panel to check them.
Posted on Apr 29, 2010
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Lloud road noise when driving
Tyres maybe....or wheel bearings if it is like a whoosh...whoosh noise
Nov 17, 2013 | 2003 Ford Explorer
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Husband overloaded it it is getting hot but when it spins it makes a triibly loud noise now and then stops spinning after a minute
Sounds like maybe a bearing, a wheel, or a glide problem.
Not all dryers are made the same, I have posted pictures and videos for American dryers HERE
Post back your brand and model and I can be a bit more specific.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2011 | Dryers
While the dryer is running there becomes a loud noise and it automatically shuts its self off
May be your motor shutting off on its overload. If you can start it right away it may be something else but if it takes 5-10 minutes before you can start it again its probably the motor. Make sure a sock or something isn't caught in the blower wheel.
Sep 21, 2011 | Crosley CDE6000 Electric Dryer
A loud banging noise when dryer is running. Sounds like washer does when it has an uneven load. But dryer is not even close to being overloaded. Since it is a top loader dryer and the drummer rolls shut...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 23, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Loud noise in front/side. When make a sharp turn
most likely a cv axle if it makes popping noise in turns
Jul 07, 2010 | 1991 Subaru Legacy
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
151 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
