EMachines T2958 Destktop Computer Power Problems
Ok, so we just moved & when I pulled the computer out of the box it was in, the face-place of the como thputer came off. 3 wires pulled out with it. This is the colors & what they say:
HDD LED- RED & WHITE
PWR LED- GREEN & WHITE
PWR S/W- BLACK & WHITE
Now ALL I need to know is in WHAT ORDER do they go back on the little strip with all the prong things...
Really need this computer back up & running!! Please Help Me!!!! :
  • 18 Answers
There are several things to think about here. First off, you have *six* wires ... 3 pairs ;-)
1. Your computer only *NEEDS* to have the power switch wires (the black/white pair) connected, so if you can figure out where to hook these up, the computer will work. The "LED"'s are just lights so that *you* can tell it's on and when the hard disk is being used.
2. I can't say for sure, but most manufacturers put these wires into some sort of arrangement that plugs into a one-way connector ... in other words, the wires are all ganged together in one "plug" and there is a tab or projection or slot that keeps you from putting the wires in the wrong way. If your wire sets are connected in one plug, it's should be fairly simple. From the sound of it, though, they're separate, so keep reading.
3. Make sure your computer is plugged into power. Take a pair of needle-nose pliers with rubber handles and place the point between each set of two prongs, so it is "bridging" between them. You will be completing a circuit with the nose of the pliers (it's fairly low power, but use the rubber handled pliers anyway for safety). When the computer starts, you'll have found the two prongs that the black/white pair should be attached to. It doesn't matter whether the black goes to one and the white to the other; it's just a switch.
After this, you've only got 2 wire pairs and 4 prongs left, so trial and error should allow you to connect the other wires. I'd start with the Green/White pairs first. When the computer is ON, the LED for power should also be ON.
Good luck with your troubleshooting!
Posted on Apr 28, 2010
Testimonial: "That was helpful, but now I'm pretty sure our motherboard is no longer working. :( I've placed the power switch in every position possible & no luck."
I want to clean the dust from my tower and blow canned air, but does the blue plug on cord pull straight out ?
Dear bonnie,
Years ago, on a computer tech help site, I read a posting warning against this unless a last resort? It said that if all was well - leave it be! as moving dust from where it has settled could possibly cause a 'short-circuit' & burn out components. Also do not know which cable is "blue plug on cord"? Make sure power is off at wall. The power plug pulls straight out from computer. Other plugs have obvious screws/screw-posts. If you are going to fiddle around inside your box, best practice is to wear an anti-static wrist band attached to metal screw/frame with power OFF at wall but leads still plugged in - (this will ensure that the computer is earthed & your body static - up to 50,000volts! - will not fry any components). I hope that this helps - kind regards - 'b'ye - Bruce.
Jan 01, 2014 | E-Machines eMachines Desktop PC
I have an emachines t2958. Somehow the administrator log in was deleted completely. I cannot get onto my computer with any administrator privileges. I've tried rebooting and the restore disc. Nothing...
Use another PC and Search for "Administrator password reset" to download a reset tool. You'll have to write this to a bootable CD. My favourite such tool is a utility call AnyPassKey.
Dec 21, 2013 | E-Machines (T2958) PC Desktop
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
How to restore to factory settings
  • Use a memory device such as a rewritable DVD or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
  • Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard and mouse. Bring up the "Start" menu and choose "All Programs."
  • Navigate to "eMachines" and then "eMachines Recovery Management." Click the tab labeled "Restore," which is located at the top of the window.
  • Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and then click "OK." Click "Restore System to Factory Default."
  • Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
  • Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appears on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
  • Mar 10, 2011 | E-Machines (T2958) PC Desktop
    I need to reboot my emachines T2958 lost CD.
    You will have to call E machines and buy one - sadly
    Apr 21, 2010 | E-Machines (T2958) PC Desktop
    I have a T2958 and toof the face off. Can you
    eMachines doesn't give out this kind of info, and I don't have one in the shop.
    eMachines also had the habit, of using a few different manufacturer's of motherboards. Intel, TriGem, MSI, Asus,and FIC to name five.
    Plus eMachines would use whatever was available at THAT moment, when they were producing that particular model line. (Not stating the T2958 specifically. Whatever model line they were making at the time)
    Plus at the time the T2958 was made, Gateway had bought out eMachines. (eMachines later bought themselves back)
    However all is not lost here. At the time the T2958 was made the motherboards were manufactured by Intel.
    The Intel D845GVSR
    Uses the Intel D845GV MCH, and the Intel ICH4 southbridge chipset
    (MCH. Memory Controller Hub. Intel's naming for their Northbridge chipset)
    http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2958
    You are looking to see where the wires go, on the Front Panel header of the motherboard, from the Front Panel of your computer.
    (Front Panel header on a motherboard, is essentially where the wires go that come from the Front Panel of the computer. When referring to a connector on a motherboard, a connector is a Header.
    The Power On switch wires, HDD Activity Lamp, Reset switch, {If used}, and Power On Lamp, are located in the Front Panel, for your computer)
    {Front Panel = 'Face'}
    As stated, eMachines does not give out this info.
    I just need your patience, and your eyes. I need you to compare a photo of a motherboard to yours.
    When you open your computer case, the side cover should come off of the Left side.
    The back of the computer will be to the Left, the front to the right.
    The Processor will be at the top of the motherboard, and the Ram Memory slots will be to the right.
    Observe the motherboard photo at the top of this page,
    http://www.dexplor.com/phpBB2/viewtopic.php?f=13&t=7747553&sid=8fa7e78bbadfbd6fde083b28641248cc
    Orient in your mind so that the motherboard in the photo will have the Processor to the top, and the Ram Memory slots to the right.
    Should you have no idea of what I'm referring to here, please come back, and state so in a Comment.
    The Front Panel header is composed of three individual headers, (Connectors) for this motherboard.
    J9F2, J9G1, and J8H3
    The J9F2 is for the USB ports used in the Front Panel. We won't be concerning ourselves with this header.
    J8H3 is located to Right side of the CMOS battery. It has two pins sticking up.
    This is where the Power On LED light plugs into, IF, the Power On LED light has Two wires, and the light is one solid color when lit up.
    J9G1 is located below the CMOS battery, and is located on the bottom edge of the motherboard.
    There are two rows of pins sticking up.
    The rows are parallel to the edge of the motherboard.
    The top row has 4 pins.
    The bottom row next to the edge of the motherboard has 5 pins.
    The pins are numbered from the Left, going to the Right. There MAY be a number 1, or 2, stamped on the motherboard.
    I wouldn't count on it.
    The top row of pins, going from the Left towards the Right are,
    2, 4, 6, and 8.
    The bottom row of pins going from the Left towards the Right are,
    1, 3, 5, 7, and 9
    There is no Pin 10.
    1) Pins 1 and 3 are for the Harddrive Activity light. (HDD)
    2) Pins 2 and 4 are used for a Power On LED also.
    3) Pins 6 and 8 are for the Power On switch
    Should you have more questions concerning this, please state so in a Comment.
    Mar 06, 2010 | E-Machines (T2958) PC Desktop
    Hp desk top will not turn on
    First open cpu cabinet and pull cmos cell for 10 minutes from motherbord then all settings are defaults.
    Then check .
    If still face same problem then you have to change your SMPS it is square box on back top side of cpu .
    Aug 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
    EMachine T2958 - No power
    You are right about checking PSU first. Check PSU by using a PSU tester. If you don't have a PSU tester you can go to any computer reapir shop and have them check out the PSU for you.In case PSU, is fine there is a possibility that motherboard may be shot.
    Nov 05, 2008 | E-Machines eMachines Desktop PC
    T2958 continuous startup cycle
    It sounds like there may be an issue with the memory chips. If available, take a memory stick that matches the type of memory you need for your computer. Take out all memory sticks on the motherboard and try the new memory stick in the first memory slot and see if you get the error. If so, then try it in the second memory slot.
    Aug 20, 2006 | E-Machines (T2958) PC Desktop
    Computers & Internet Logo
    88 people viewed this question
    David Payne
    David Payne
