Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Ice maker does not feeze or make ice anymore - Samsung RF265AA Bottom Freezer French Door Refrigerator
  • Samsung Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Apr 27, 2010
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
My kenmore 52672200 ice maker does not make ice anymore
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 25, 2010 | Kenmore 52672 / 52674 / 52679 Side by Side...
My ice maker doesn't work anymore
heatman101
Oct 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Ice maker stopped working. water still dispenses but no ice is forming anymore. can you help?
heatman101
ghhdg
Feb 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
FREZER NOT FEEZING SOLID
you must defrost it. and it will work again about 3 hrs with fan blowing in the open door .. the cooling coils are froze over with ice .. kool fix
Jan 31, 2010 | Maytag MSD2651 HE Side by Side...
The ice maker doesn't work. I can get cold water from the refrigerator so I assume that the line is not frozen. I just changed the water filter to see if that might help but it didn't.
Check the folllowing:
The end of the ice chute inside the freezer compartment that dumps into the ice tray - they can feeze and block water flow.
Remove the water chute and see if the water orifice is frozen. If so, it will block water flow. it can be thawed out with a hair dryer (carefully).
If no luck, look for a bad water valve or possible kink in the water line. This valve is usually located under the back of the fridge behind a cover.
If all ok, there could be an issue with the ice maker itself or on some units, a control circuit board.
Try unplugging the fridge, let it sit for at least 5 minutes and then plug it back in and see what happens.
Apr 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
131 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
