Question about Watches
The metal mesh watchband is is coming apart. Can it be replaced or repaired?
  • 299 Answers
Any watch shop or jeweler should have an assortment of replacement bands suitable for most watches or can order a specific brand if desired.
Posted on Apr 27, 2010
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
BG6070 strap
This might be of some help:
http://www.genevawatchgroup.com/pdf/repair/repair_bcbg.pdf
This is also a place to order a replacement:
http://www.watchbands.com/custom.aspx,,id,,34,,Request-a-BCBGMAXAZRIA-WatchBand-Quote
Dec 09, 2012 | Bcbg Max Azria Bcbg Maxazria Casual BG6070...
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    Omega watchband adjustment (Metal) pins or screws?
    mcdevito75 here, That would depend on the band itself, I would figure most are pins, your best bet though is to look for a small watch repair shop in your area for this adjustment, special tool needed.
    Aug 11, 2010 | Omega Watches
    I have a silver/gold braided watchband and the clasp keep coming undone. Can I replace the band itself or have the clasp repaired. Marianne Wadle 515-28-50866
    Your watch clasp alignment is off , that's make it lose,, most of the time i able to fix it if not then replace with new one, I hope this info helpful
    from
    Amfix Jewelry & Watch Repair
    203 N. LaSalle Street
    Chicago, IL 60601
    Ph : 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Aug 28, 2009 | Watches
    The rubber watchband is broken apart from the screw in two areas. Is there a replacement band available?
    yes,if your watch is in guarantee period then go to company's repair centre they will replace it for free.
    and if your watch is not in guarantee period then
    go to any watch repairing watch shop ,they will insert a new,it costs you according to the material you want for the watchband.
    enjoy
    please rate me
    Jul 12, 2009 | Haurex Unisex "Piranha" Watch
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    How and where do I get a watchband replaced or repaired?
    Any watch store should have a pin for you and they don't cost much. Good Luck. Bill
    May 27, 2008 | Fossil Watches
    Seiko Watchband to long
    Kept looking thru Google and found THIS site that seems to answer the question for MANY styles of METAL watchbands.
    http://www.geocities.com/watch_crazy/index.htm
    Dec 06, 2007 | Watches
    Watches Logo
    24 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
