Question about Dishwashers
Hobart fx 10 Dishwasher
Our Dishwasher at st davids broomhouse has a manual fill for the rinsing fluid .
But if was filled with with disinfectant used for cleaning work tops,flooers
how can I clean this out or do we call engineer to call
  • 126 Answers
SOURCE: Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Posted on Dec 13, 2007
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
  • 13 Answers
SOURCE: rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Posted on Nov 15, 2008
  • 3 Answers
SOURCE: not filling water not rinsing
call 828-484-9562
Posted on Mar 06, 2009
bigg t
  • 640 Answers
SOURCE: Hobart dishwasher rinse buket filling water
Can you be more specific please?
Posted on Mar 11, 2009
We have a hobart am 14 hotwater sanitizing dishwasher that no one knows how to use, how can I get an instruction booklet?
Go to hobartcorp.com instuction manual are available on its site to download.
Makes sure all screens are in nothing in tank under them (spoons especialy). turn power switch on, shut door and it fills, should say fill on led display. once its filled open door and put tray in shut door and it starts wash cycle. led will say wash then it will go into rinse. when risnes dispaly turs of its finished. open doors take tray out. put next tray in. to drain out to clean there is a little moon shaped lever right above basket it will life the drain stand pipe greay plastic tube under screens and it will drain out shut door turn on the switch and it will fill back up and off you go. Soap wil be with a privet vendor if you have a already installed soap system call them and they most likely have reps who cann show you you basics.
Best Dishwasher Hobart ever built is the Am-14
Aug 19, 2011 | Hobart AM14-253 Free-standing Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Jun 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The wrong rinse aid!
Vacuum out with a wet/dry shop vac. Suction will pull most of it out. Then fill with water and do it again. You should be good to go.
Jun 19, 2009 | Miele G2430SC Dishwasher
Rinse probe
If standing in front of the dishwasher,look to the right in the back on top you will see a valve and guage.You will see the rinse/fill pipe and the probe screws into that.I'm a hobart tech--Any questions let me know.
Mar 04, 2009 | Hobart AM14-253 Free-standing Dishwasher
Older hobart kitchen aide Supera by hobart KDH7A
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
Nov 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dishwashers Logo
179 people viewed this question
Top Dishwashers Experts
