Question about Polaroid 4241-TLXB 42 in. LCD Television
The picture just freezes up and will take no command from either remote or side buttons.
Shitcan the tv this set sucks!!
Posted on May 17, 2010
  • Polaroid Master
  • 1,210 Answers
You need the small signalboard replaced!
Posted on Apr 27, 2010
Nikon D7100
Oops, look how your command rail on the left side is. My guess it is not on S (single shot) but on the remote sign just next to Mup.
I think you never forget after this.
Nov 30, 2013 | Nikon D Cameras
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    I cannot get the picture-in-picture off the screen
    Hello
    You must press function before you can control PIP with the yellow labelled buttons.
    Press to change the TV channel in the window picture.
    Press to move the location of the window picture [counterclokwise] around the main picture.
    Press to freeze the window picture with Freeze button.
    Press freeze button on the remote handset again to restore the previous screen.
    Ok
    Oct 26, 2010 | Sony KV-27V65 27" TV
    Remote freezes
    Hi. If your remote is freezing, you should try updating the firmware from safe mode.
    1. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode".
    6. Connect your remote and log in to your account.
    7. Click "Downloads" at the top and select "Firmware". The firmware on the remote will update.
    8. Click "Replace Remote" to conduct a connectivity check.
    9. Update the remote.
    That should fix it!
    Mar 23, 2010 | Logitech Harmony 1100 LCD Touchscreen...
    Red/ Bright Tint/Color on Sylvania SRCD227
    Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
    To teach your Harmony 550 a new button follow these steps:
    1. Connect your Harmony remote to your computer to start the Harmony remote control software.
    2. Click Devices.
    3. Click a device.
    4. Select Learn Infrared Commands.
    5. Click Next.
    I hope that helps.
    ___________________________________
    Harmony 550 Manual Download
    Logitech Harmony Firmware Update
    Harmony Mac Software Download
    Harmony Win Software Download
    Logitech Harmony Safe Mode Fix
    Harmony Remote Glow Light Fix
    Feb 11, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
    Comcast freezing up...NEED HELP NOW!!!
    Possibly a bad remote? The cable box might also be defective. Call tech support.
    Jun 29, 2009 | Televison & Video
    Deactivating tv remote control codes
    I am not certain these are the instructions for your specific remote. If you are brave, give this a try.
    To Clear all Learned Commands under a mode
    Clearing learned commands is helpful if, for example, you
    replace your CD player with another brand or model. If
    you had learned a feature from your old CD player’s
    original remote on to this remote (such as RANDOM
    PLAY), that feature would no longer work for your new
    CD player. Should you wish to remove or clear one or
    more “learned” commands, follow the steps below:
    1. Press and hold the SETUP button until the red
    indicator turns on. Release the SETUP button.
    2. Press and release the button for the mode you want
    to clear (TV, VCR, etc.). The red indicator blinks off.
    3. Press and release the LEARN button TWICE. The
    4. Press and release the SETUP button. The red
    indicator turns off. All learned Commands under that
    mode are now cleared.
    Master Clear - To Clear all Learned
    Commands under all modes
    2. Press and release the LEARN button TWICE. The
    3. Press and release the SETUP button. The red
    indicator turns off. All Learned commands in the
    remote are now cleared.
    If you would rather error on the side of caution, here is the link to Philips Customer Assistance. It will help you locate the correct model number and the appropriate User Manual.
    http://www.support.philips.com/support/html/index_us_en.html
    I hope this helps, good luck!
    Kym McC
    Oct 05, 2008 | Philips Magnavox Learning Universal Remote
    Don't have manual...don't know how to use some buttons
    My guess on surf is it might scan channels for you. PIP is short for picture in picture and may require a second device with a seperate tuner. SWAP works with PIP button and switches (or swaps) between the pictures. FREEZE probably "freezes" picture until you push button again.
    May 14, 2008 | Zenith MBR3447 Remote Control
    I want to know how to use some features on my Zenith MBR3447 remote
    My guess is SURF might let you scan through the channels like a scan button on a car radio. PIP stands for picture in picture and may require a second device(vcr etc.) with a seperate tuner to use. SWAP allows you to swap pictures when useing PIP. Freeze probably will allow you to freeze the current picture on the screen.
    Polaroid 4241-TLXB 42 in. LCD Television Logo
    112 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
