Question about LG Washing Machines
Lg wd-8013f CHANGE THE LID SWITCH DOSEN'T FIX
  • zht984112 Apr 28, 2010
    press power and select "Quick 30", press start,
    then the lights for
    90'c; 60'c; 40'c; 30'c and cold; Pre wash; Rinse+; Rinse Care; Crease Care;
    keep flashing;
    lid closed properly, machine has no move, no noise;
    lid switch has been changed, many thx if you can provide help
    press power, select "quick 30", press start,
    then all temperature lights and those 4 rinsing lights keep flashing, other that, no noise, no move can be seen from the machine.
    President:
  • 1,554 Answers
I assume the machine had a spin problem and you replaced the door switch. Please provide more details to properly troubleshoot the problem. Limited information limits the chance of determining the source problem.
Posted on Apr 27, 2010
  • Jahn27
    Jahn27 Apr 28, 2010
    It is clear that the door switch is not the problem although the flashing of the mentioned lights may indicate a faulty door switch. This signifies a malfunctioning machine control but make the connections of the door switch, water inlet valves, drain pump, and the heater to the machine control are snug fit. Clean the connectors and terminals then reseat it several times to ensure a good and snug fit connection.
  • Jahn27
    Jahn27 Apr 28, 2010
    The water inlet valves, drain pump and the door switch have a common connection which is then routed to one of the heater terminals via the door switch contact and a red wire. A loose connection or discontinuity in this circuit can trigger a door switch error. Disconnect the water inlet valves and the drain pump wiring harnesses then with the door closed, check the continuity of the middle terminal of the 3-pin white connector on the machine control board to the heater terminal with red wire. Review the wiring harnesses and check for any loose or cut wire if no continuity is established with the closing of the door. Replace the machine control if a continuity is established.
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Washing machine lg intello wash wd 8013f
Is your washer getting power? The first things to check are your circuit breaker, lid switch, or fuse box. After making sure there is power or no power to the appliance, you can start troubleshooting other problems. To verify there is power at the outlet, try plugging in a small electric appliance such as a hair dryer or radio. Sometimes the motor will overheat and then requires a cool down period before it will restart.
Is the machine in a pause cycle? Is the lid up? Washers will not run if the lid is up. There is a lid switch probe that can sometimes become dislodged. This is generally a little plastic piece that is in the hole under the lid on the washer. This probe activates the lid switch when the lid is put down. Manually advance the timer if the pause is too long.
There are some washer models out there that will not run at all until the water is filled to the level that has been selected. Sometimes the mechanical timer knob on certain washers doesn't exactly line up with the graphics on the control panel. You can try advancing the timer slightly and pull the knob out again to see if it will start.
Sep 04, 2008 | Washing Machines
Washing Machines Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
