Question about Intel D102GGC2 Motherboard
Will 2gb ddr2 800mhz ram support intel desktop board d102ggc2
D102 supports upto 533mhz..so u cant
Posted on May 21, 2010
  • 4,737 Answers
I hope this is the motherboard you are asking about, if it is so, it does not support DDR2 800MHZ, it supports only DDR2 400MHZ. Don't get confused with the bus speed as it is 800MHZ.will 2gb ddr2 800mhz ram support intel desktop - intel-d102ggc2-.jpg
Posted on Apr 27, 2010
3 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: inteldesktop board D102ggc2 drivers
http://www.intel.com/design/motherbd/gc2/gc2_drive.htm
There u go!
Just select your OS and you will see all avalible drivers for your MoBo!
Good luck to you
If you find my answer helpfull, pls dont forget to vote
Posted on Dec 28, 2008
SOURCE: Machine randomly restarts after upgrading RAM
brother...
d102ggc2 only support max 2 gb ddr2 which mean (2x1gb) with 533mhz each,
if you replace ur curr ram module with two seperate transcend 1 gb ddr2 533mhz only then the problem will be solved...
take care
Posted on Jul 02, 2009
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Will 2gb ddr2 800mhz ram support d102ggc2
No. The maximum system memory that can be installed in 2GB, that being two 1GB RAM modules, Also the board only support DDR2 400 or DDR2 533 RAM.
Jan 07, 2012 | Intel D102GGC2 Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
I have 2gb of ram.but system detected 1 gb of ram
Make sure the board supports 2 gigs of ram, and make sure the board supports the type of ram you installed.
This info can be found either on the manufacturers website and/or the user manual that came with the board.
Mar 01, 2009 | Intel D102GGC2 Motherboard
Memory channel mode
Hi shinde32, you should know that dual channel memory should be bought as a pair. Your board has two DIMM slots as you mentioned. The board can handle up to 2GB max memory, as you have mentioned. What you do not seem to know is it is required to use the same amount of memory is each slot. See the bottom of page 55 in your manual. (Do you need the manual)? Download at this link;
http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf
There is not a bios setting where you can enable or disable memory channels. The bios configures the memory automatically. Intel has a list of memory tested & passed for the D102GGC2 Mb. You can see that list at this next link.
http://www.intel.com/technology/memory/ddr/valid/DDR2_sodimm_results.htm
Bottom line, both DIMM slots should have two 512MB DIMMS or two 1GB DIMM's. (Like this memory);
http://www.bzboyz.com/ProductDetails.asp?ProdID=18112
https://www.thefind.com/computers/info-spd-dual-channel-kit-memory
This is what your search would look like,
"1GB x 2 DDR2 dual channel 533MHz SPD memory".
The Certified "SPD" is important for Intel MB's.
Good luck shinde32!
Need more help, post here.
Thank you for using fixya.
Mike
Jan 15, 2009 | Intel D102GGC2 Motherboard
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
340 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
