Question about Acer Aspire 3680 Laptop
No sound Hello, i have no sound coimg from my speakers. According to the error message i have no audio device om my computer. Is it possible to download an audio device?
  • 655 Answers
Friend you can download the Audio driver from acer website.
Click Here to download:
This is a zip archieve unzip and make install.
If still have problem just Ask Me i will help you.
Thanks
Iqbal
Posted on Mar 24, 2008
    Genius:
  • 3,587 Answers
Open control panel, sounds settings, and see if it's listed there..then go to system device manager, and look for the codecs..make sure they are clean.
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
I brought a new GA-G41M Mother board problem is in my audio which is not working. When i install the drivers an error is displayed cannot find hd audio device. Help me pls
what does the error message say???????
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
hope it helps
Apr 27, 2012 | Computers & Internet
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My computer is not detecting the new speakers that i just plugged into it
install the audio card driver ,,, the problem is not with your speakers it is with the audio card ,,, you must install the driver,,
Mar 14, 2012 | Sony Audio Players & Recorders
Error message; no audio device, no sound from speakers.
if your computer came with a motherboard disk the drivers could be on it
sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers:
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
((appropriate speakers)) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jul 08, 2011 | Computers & Internet
I get power to the stereo but no sound comes out
Hello eklypss2000,
According to the manual for the Alpine CDE-102, the message "DC ERROR" is displayed if there is a short to ground in the speaker wiring. Check all of your speaker wires and make sure that no bare wire is shorting against the vehicle metal or against other wires. Repair or replace the wire as necessary. After correcting the problem, set POWER IC to "POW ON" according to the instructions in your manual.
Hope this helps.
May 18, 2009 | Alpine Car Audio & Video
Speakers not working, but cables all plugged in...
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
Oct 21, 2008 | Logitech S200 Computer Speakers
I am unable to get speakers working.
There is small logic to resolve or to narrow down the Audio issue.
Let me explain.
First, try to play any audio file and observe if is giving any error message or it seems to playing without sound.
If it gives any error message like "No Audio/Media device installed or found", then the audio driver is not installed in the computer or the Windows Audio serviceis stopped.
If it seems to be playing without sound, then somewhere it might be muted or Sound level might be lowered.
If you are sure that all settings are okay and not Muted, then you have to check with another speakers or headphones.
If another speakers works, then the issue is with the ols speakers.
Please get back to me if you need more information on this issue.
Aug 09, 2008 | Gateway Computers & Internet
I purchased a sound blaster X-Fi extreme audio notebook card, installed iti into my XPS M1730 Dell laptop computer amd I can not get any sound, AT ALL. Please help me to be able to get a 5.1 surround sound...
Hello!
im affraid to answer your question because in most cases you will rate me " thanks for trying" it hurt me but it's ok because i want to help you.
First install the driver of your "sound blaster X-Fi extreme audio notebook card" the Utility cd is enclosed in it. after that Hook your speaker to the output of the newly installed card. and then go to control panel , double click the "sounds and audio devices" and then in the "audio tab" and in sound playbak. select the device according to your sound card.
You can adjust some setting there and click ok.
may this solve your problem.
best regards,melnavz
Mar 07, 2008 | Audio Players & Recorders
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
