Question about Fisher and Paykel GWL11 Top Load Washer
Puddling on floor during high speed spin cycle
Put wash machine on saw horses and run through a full wash cycle. NO leaking during fill, or rinse. During the spin cycle the water was puddling on right side of machine as I face the machine. Any ideas to resolve this issue? Thanks for your time.
  • Anonymous Mar 15, 2014
    washing machine smoke during spin
  • 1,557 Answers
You have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Posted on Apr 28, 2010
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
E47 and no spin cycle on ATF8000fs1
E47 error is for the door lock assembly. Here is the part to order.
Here is a video to show you how to make the repair.
Dec 06, 2012 | Washing Machines
Does not spin clothes dry
Run the washer empty on the lowest water level. Cold will save energy. Watch it fill, close the lid, stay there. Don't advance the timer no matter how tempting as this could skip a program interval. When you hear the water draining listen for a sound change and open the top and see if it drained completely -- pumped out empty. Close the lid so the cycle can continue. During the spin cycle open the lid. See if the drum was really turning fast -- it will be slowing down as soon as you open the lid because that stops the motor. If everything seems normal, then the problem may be transmission or belt slipping under load. Do you have the problem only on large loads? If the spin speed is slow during the test then the transmission is not shifting in to high, controlled by a solenoid. Check the solenoid for power during the spin cycle. Operate the washer on blocks or outside on saw horses to see full function of underneath parts and have access to electrical wires for testing. Use precautions testing and plug into a GFCI. Take your car battery jumper cables and clamp to a water pipe ground and to the underneath frame where the motor mounts. This should keep you from getting electricuted standing in water and holding a test meter.
Dec 12, 2009 | Washing Machines
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
474 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
