Lexmark image studio
I AM UNABLE TO USE IMAGE STUDIO APPLICATION. WHEN I TRY TO OPEN IT I GET MESSAGE "PRINTING APPLICATION HAS ECOUNTERED A PROBLEM AND HAD TO CLOSE". MY PRINTER IS LEXMARK X4550 HAS ANYONE ANY IDEA WHAT THE PROBLEM IS?.YOUR HELP WUOLD BE VERY MUCH APPRECIATED. DAVE
  • 1 more comment
  • Anonymous May 06, 2008
    I am having the same problem with the image studio that came with my lexmark 1400 series printer. When I try to open it the following message opens:
    Lexmark Imaging Studio has encountered a problem and needs to close.
    If you have a solution please e-mail me at [email protected].
  • Clueless30 Oct 11, 2008
    Lexmark 1300 Imagining Studio printing application has encountered a problem and needs to close. I have tried uninstalling and installing and it still doesn't work, please help.
  • ISLA47 Mar 24, 2009
    AFTER USING IT WITH NO PROBLEMS I AM NOW UNABLE TO USE IMAGE STUDIO APPLICATION. WHEN I TRY TO OPEN IT I GET MESSAGE.PRINTING APPLICATION HAS ECOUNTERED A PROBLEM AND HAD TO CLOSE.. MY PRINTER IS LEXMARK X4550.
    PLEASE HELP!!!!!
I had the same problem.This worked for me.
Insert the disk
When the install window appears click cancel
click Start>My Computer>
Right click on the drive with the disk in, and Open
Open Applications (left double click)
Open LaunchPad (left double click)
Double click the icon LXCRlpx
Go back to Applications and double click on Set Up (the disc icon) from there and then follow the install instructions.
This worked for me, I hope it does for you.
Posted on Apr 15, 2009
SOURCE:
Won't work, how do i fix it?
plz try by reinstalling the software and scan your system for viruses
Nov 06, 2009 | Lexmark All-in-One Printer with PictBridge
My printer wont scan every time i try it says can not retrieve application list what does this mean?
Please follow the steps given below to add applications to Imaging studio:
1. Open the Imaging Studio and then click "scan," after the scanned document appears as a preview.
2. Click "Other Software" at the bottom.
3. That will open up the list of application list, to modify the application list, click on "Modify Application List".
4. Please add the application you want to scan and click on "Close."
Aug 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Problem with Imaging Studio
I have a Lexmark 2500 and was also unable to download the Imaging Studio. I was able to fix it by inserting the CD but not allowing the computer to install it. I went to my computer and right clicked on the CD and opened the files on the CD. I clicked on the Applications File Folder and opened it. There is a Setup/Setup Launcher that has a pic of a CD and shield next to it. I clicked on that and installed the Imaging Studio. Although it did not say Imaging Studio that is what installed! I never had to uninstall the printer only download that application. I'm so happy to have it working!! I have installed it on 3 computers! I hope this works for you!
Aug 09, 2009 | Office Equipment & Supplies
Have a Lexmark X5470; when 'Scan Mode' is engaged,
on your computer: click on start all programs / programs check for the lexmark folder ( lexmark 5400 Series ) check if there is any application under it ( AIOC , Productivity Studio, or Imaging Studio ) If there is: check your firewall, this might be blocking the application list. If there's none: Using the disc: Start My Computer / Computer Open your CD/DVD drive where the lexmark disc is Open application folder Run Setup under application folder. This should update the software
Mar 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x2470 how do i scan
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Being scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 16, 2008 | Lexmark X2470 All-In-One InkJet Printer
I have a Lexmark x2470 and it works great. But ever since I got it I have never figured out how to scan to computer. Can you help?
The easiest way to scan to computer is to use the Lexmark Imaging studio Application. This should have been installed at the same time as the driver software. In the Imaging studio you have several options. Select SCAN and follow the prompts. For example to scan a photo select SCAN. On the next page select -send scanned image to: Lexmark Photo Editor. Below that it will say "what is Beig scanned" select the appropriate button and click the "scan now" button.You can also use the - send scanned image to: - drop down box to send the image directly to another application such as WORD, PAINT, clipboard, file or fax. If you have any problems that are more specific contact me or another tech on the chat line for help.
Dec 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark 2500
Every time I try to run the scanner or open the imaging studio I either get a App4r.exe or Device Monitor application problem error message
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
Jun 22, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark Z53 prints photos on 'normal' but enlongates image on 'best'
I'm getting around the problem by using Windows or Nero print options to get the photo as near to the size I need. It would be good if I could print photo's from Photo studio though much simpler and less time consuming.
May 23, 2008 | Lexmark Z53 Color InkJet Printer
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Not printing or scanning at high resolution
If the Lexmark software doesn't work you could just try using other software. Picasa http://picasa.google.com is a free photo management software and does a great job of printing photos. You can scan from an application like Word or using the "Get Picture using Scanner Wizard" menu that shows up when you right click the Scanner in My Computer in Windows.
Sep 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
Computers & Internet Logo
1,098 people viewed this question
Ekse
Alun Cox
