Question about GE Zoneline AZ28E12DAB Heat Cool Air Conditioner
Fan starts when unit is off - GE Zoneline AZ28E12DAB Heat Cool Air Conditioner
  • 26 Answers
It has an unoccupied set point.
Posted on May 06, 2010
LR-350 keeps on turning off
Check the wiring for the fan and the temperature sensor. If the fan isn't running/broken the unit will not start or ignite. Try moving the fan blades with the unit unplugged. If they don't move easily or are ceased the fan may need replacing or lubricating. The heat in these units dries out the fan bearings over time.
Dec 13, 2014 | Heating & Cooling
Is there a reset button on a FASCO D9709 AC unit?
Hello, the fan in the interior unit takes a few minutes to start in heating mode.
If you are talking of the fan in the exterior unit, then that fan is stuck or burned.
If you try to use in cold mode and the fan of the interior unit dont run, then you have problems in the electronic board.
Sep 15, 2014 | Heating & Cooling
My window air conditioner of 12 years turns on but does not blow air. What do you think the problem is?
Fan barrel not turning. Could be a failed start capacitor or tight fan. With the unit turned "OFF", see if you can freely spin the fan. If so, turn the unit on and give the fan a spin. If the fan starts to run, then it will be a start capacitor.
Aug 17, 2013 | Heating & Cooling
Fan on outside unit will not start
That could be a few different problems, does the unit sound like the compressor is trying to kick on? If so, it could just be the condensor coil...or the fan motor itself. I just had to replace the fan motor on my own outside unit. Check to see if the fan blade will turn with the unit both on, and off using a screwdriver or something.
Jul 15, 2012 | Heating & Cooling
Fuses were replaced first. Fan on airconditioning unit won't keep
It sounds like the run capacitor of your condensor fan failed. When it fails, it can prevent your fan from starting unless you manually spin it to get it going, then it could run for awhile before it overheats.
Apr 06, 2010 | Heating & Cooling
My craftmade celing fans/lights start strobing
SOunds to me like you have a bad wiring connection in the fan unit, have someone check out all the connections, both between the fan and ceiling and the fan and light unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 18, 2010 | Craftmade International Electrical...
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Exterior Fan not starting.
Its the problem with the fan. !1 or more coils have burnt out and if repaired will have to rewind the shorted coil/armature. Better to replace the fan. Also when getting it repaired ask them to check the thermostat too...............sodeep
May 16, 2009 | Heating & Cooling
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
