Question about HP W2007 LCD Monitor
It makes a buzzing sound then goes black!!
It stays on for a few minets then it goes black!! when i turn it off and back on it stays on for a few min. agin!!
  • 732 Answers
Nogooddeed, Yes, You too, will need to visit this blog that is quite old, but still of some importance!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ And if you need more info on bad capacitors or poor soldering (failed solder joints of active or passive electronic components to printed circuit boards) you will need to visit YOUTUBE for video clips of DIY repair of black and or blank n black screen "cold-cathode-fluorescent-lamp" back-lit lcd monitors. Keep in mind that your W2007 is no different than any other brand of ccfl lcd monitor in it's basic design and operation!!! When you understand the "flashlight test" that every ccfl back-lit lcd owner should know, then come back and let us know what your plans are for your display. To read my profile or any other fixya tech's profile just type their fixya nickname in the above fixya taskbar where it says "search for solutions or" .. Read the profiles of these tech's also: "buddymc" , "budmrtn" and my old file "louie12fix"
After you have done your research and you feel this response was of some help, please rate this response on fixya for others who will be looking for info about their monitors. Bye for now. I'm 12fixlouie
Posted on Apr 27, 2010
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Samsung ln52a850. ..works fine for a few min then
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 17, 2014 | Televison & Video
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv fades to black very low sound or or goes to blue & says lost siginal then goes toblank turn off set & waite a few min.& turn back on will only stay on for a few min. have to repeat.
This is not a "digital" problem that can be addressed in your setup or fixed at home. This sounds like a fading power supply. Often electronics fail slowly or partially.
You will need to consult a TV repairman.
I hope this helps!
Jun 15, 2010 | Olevia 237T 37 in. LCD TV
Tv is on, after a few minutes it goes black and there is no sound. The indicator lamp is still green and stays solid the entire time. Without turning the TV off, in about a minute, you hear a small buzzing...
Someone else gave me the tip as I had the EXACT problem, but no buzzing. Unscrew the panel on the front bottom of the tv. Once that is off, there is another screw that opens a little panel. Unscrew the single screw with an allen wrench and pop out the bulb and casing. Mine was full of dust etc. Used an LCD cloth, but compressed air would do the same thing, put it back together and it works great!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
Screen goes black
Check and make sure the software is updated on the set.
Aug 19, 2008 | Televison & Video
Sony wega hdtv
Sounds like a bad solder joint in the power supply or if your audio stays when you lose the video its probably in the deflection circuit either vertical or horizontal. Check the yoke connections.pins for cracked solder as well as the vertical and horizontal outputs also around the flyback.
Jan 21, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
HP W2007 LCD Monitor Logo
865 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
