Remove write protection from portable drives
I use three different USB portable tools, storage drives, flash drives & memory sticks, never had the problem before but I now cannot delete, remove, copy, add or transfer files etc, I experience exactly the same situation where a message box indicates that the device is write protected pls remove or use another disc, cant find a solution, there are no switches, what should I do, I tried to find the solution through my computor device mananger but there is nothing there to indicate a problem, Please help, I need these tools for my work.
  • maguip Mar 28, 2008
    replacement will not resolve the issue, all my portable drives etc are from different makers and yet they all have the same problem, I apologise however that I did not indicate that I use all these drives on a laptop, it seems to me that I have an Internal problem with the computor and not with the drives, I have tested these on another computor and they all work fine.
  • 871 Answers
I too also have that same problem with my sdcard reader/writer with a sdmemorycard 1gb. the only solution that i found was to replace the reader/writer itslef.
what specific medium gives you this problem? storage drives and memorysticks dont usually have problems like this. only the ones which have a detacheable memory.
so my advice to you, if you are having the same problem, look for a replacement. that will be the only solution.
Posted on Mar 24, 2008
  • earl norman llanera
    earl norman llanera Mar 30, 2008
    hey maguip,
    have you thought of using an external usb connector? the kind which requires a device driver and has its own bandwidth...
    you should try this since your laptop has a probable bad usb outlet or it recognizes some and not all...
2 Suggested Answers
SOURCE:
otacon
  • 1950 Answers
SOURCE: how to remove write protect on my usb flash drive
Are you able to format the player?
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Write protected PNY 4GB USB
Go to Start
Click Right mouse button on Computer
Click on Manage
Click on Disk Management
In the Right Panel of the drive you wish to fix
Click Delete Volume
When Volume is deleted
Click Create Volume
Follow the steps
For small drives use Fat32 not NTFS
NTFS is not portable between XP and Win 7
You may also have a virus.
Mar 27, 2014 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
REMOVE WRITE PROTECTION
Please try to use the HP USB Format Utility tool to format your USB Flash Drive.I've personally used it on even the most stubborn flashdrives.Check it out!
Download it from CNET from http://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html
Thanks and welcome.
Feb 14, 2011 | Lexar JumpDrive Classic Portable USB Data...
How do i clear 'write protection' from a removable Flash drive?
rt click the removal drive ..properties...uncheck read only.....click on the tab security...add everyone ...give full control ...apply ..ok ...it should work now..
Mar 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protection from a maxwell memory stick
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 04, 2010 | Maxell Electronics - Others
When I plug in my Lexar memory stick, and try to save a file to the removable drive (J) which is the memory stick file...it says I can't because it doesn't exist. Help?
Hi, Neil.
Look in "My Computer" to see if another drive letter was created when your memory stick was plugged in. Sometimes, another drive letter is created. Try dragging and dropping the file you want to save.
In case you are not aware, in each computer, the drive letter for a memory stick could be different, depending how a computer is set up.
Also, try in another computer to see how your memory stick works (if it's OK).
Hope this helps.
Oct 25, 2009 | Lexar JumpDrive Classic Portable USB Data...
I want to lock my data
U can use this(Hexprobe Storage Encryption Tool) software to password protect ur memory stick
Oct 23, 2007 | SanDisk Memory Media
Open Questions:
Computers & Internet Logo
1,863 people viewed this question
Ekse
Alun Cox
