Itunes When I try to launch iTunes on my PC I'll get the following message; "The folder iTunes cannot be found or created and is required.The default location for this folder isinside the music folder" We are several users of this PC and Itunes works fine for others. What should I do???? Hawkeye
    Scholar:
  • 47 Answers
You are using this computer as a limited user get the guy who is using this computer with the administrative rights to create this folder for you while use his account, i.e. make the file to your user acoount application data for you and then you try in your account.
Or the guy can just run the setting for loading itunes in your account using the run as option for him(or her) to create the folder for you.
The idea is where this folder is supposed to be created you dont have access rights to create the folder in your name.
Posted on Mar 25, 2008
Can't open my iTunes when open get error messages ""Apple application support was not found." Apple application support is required to run iTunes.
I think you have not follow the basic rule. first check your system configuration with iTunes application requirement.
If possible update your system. Now you can download a Apple Application Support file and if not helpful then read this tutorial if you have some technical knowledge https://discussions.apple.com/docs/DOC-6562#qtmoviewin
and follow Mac Technical Support for more guidance.
Jul 30, 2014 | Apple iTunes
Tip
The ITunesLibrary.itl cannot be read because it was created by a newer version...
1. Quit iTunes.
2. Locate your iTunes folder.
Operating System Default location of iTunes Folder
Microsoft Windows XP and 2000 Documents and Settings[your username]My DocumentsMy Music
Microsoft Windows Vista Users[your username]Music
Microsoft Windows 7 Users[your username]My Music
3. Open your iTunes folder.
4. Drag the iTunes Music Library.xml to the Desktop
5. Drag the following file from your iTunes folder to the Trash:
Microsoft Windows "iTunes Library.itl" (in versions of iTunes prior to 4.9 this was called "iTunes 4 Music Library.itl")
6. Open iTunes.
Important: Do not add any content into iTunes at this point.
7. Choose File > Library > Import Playlist.
8. Navigate to the iTunes Music Library.xml file on the Desktop.
Windows users: Click Open.
on Apr 25, 2010 | Computers & Internet
Can't open itunes
You need to reinstall Itunes and point it towards the correct drive/folder again. When you attached the second hard drive it would have fouled the pointers in iTunes.
May 25, 2009 | Apple iTunes
I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is...
Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
May 01, 2009 | Apple iPod MA446LL/A MP3 Player
Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Apr 26, 2009 | Apple iTunes
I combined 2 partitions into one partition using Partition Magic
In iTunes under preferences, you can go to the Advanced tab and specify the new location where you moved the folder to. By default it puts it under My Documents/My Music/iTunes Music. If you've messed with what drive that's on you need to change it in iTunes so it knows where it is.
Mar 24, 2009 | Apple Audio Players & Recorders
IPOD VIDEO 30GB WITH ERROR MESSAGE
I found this on the ipod forum on Apples website. See their site for any further assistance.
Sometimes you can resolve it by doing the following:
- Download the .exe file from Apple.com/iTunes
- Go to Control Panel > Add or Remove Programs
- iTunes > Remove
- Open C:\Program Files (default location)
- Find "iTunes" (default folder name)
- Shift + Delete > OK
- Run a registry cleaner, such as PC Tools Desktop Maestro, to remove all old shortcuts and registry keys no longer valid on your computer.
- Start > Shut Down > Restart your computer
- Run the iTunes install program
This should fix the problem, however may require also to update your Windows software (update.Microsoft.com) and download the latest Visual Basic Runtime executable. One time during my clean reinstall the iTunes software mentioned an error with a vb run executable and couldn't continue the install until I found it online.
Dec 30, 2008 | Apple iPod MA446LL/A MP3 Player
ITunes won't open
Go to "Preferences" in iTunes and change the music folder location to the location on your new disk drive. Click the boxes as shown below:
image.tiff
Dec 28, 2008 | Apple iPhone Smartphone
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
ITouch & iTunes
Firstly you will need to create a folder in 'My Music' and Rename it iTunes.
Write Back And i Wll Tell You The next stage.
Feb 20, 2008 | Apple iPod touch
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
