Question about Gateway Solo Fan Assembly
Desamble a brushless fan...
Sir,
i want to to desamble the colling fan mounted in SMPS of my CPU. but i am not getting any idea to open (desamble) it. the PCB mounted inside the fan is loose & it vibrates & make a big noice as soon as fan starts. So please help me, because if once i open it then i can repair it myself.
  • 807 Answers
Remove the label from the center of the fan.
Look inside the hole. Some have a rubber bung in the hole.
The fan is usually retained in the housing by a nylon washer with a split in it.
Get something like a really thin blade/needle and you can ease it off the fan spindle without breaking it. It sits in a groove on the fan spindle.
Posted on Mar 24, 2008
6ya staff
SOURCE:
My Desktop PC assembled is emitting quite a bit of noise. Whenever an application or a download is started, the cpu usage shoots up and the noise / vibration also increases. What can I do?
I would think the SMPS fan, sounds like it's not keeping your computer cool. CPU fans usually never cause much trouble, but maybe you could look into getting quieter fans.
Mar 17, 2015 | Computers & Internet
How to remove SMPS in Dell Optiplex 330?
Open the case, remove the cpu cooling fan, then remove the cpu itself.
Under the cpu you will see many small pins. Cut off the one closest to the bottom left. This will permanently remove your SMPS so be sure before proceeding.
May 04, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
I bought newly where i find there i no bulb inside for power on , i can denote by only when colling fan started running and surprisingly i dont find smps slot and exaust fan slot aslso not available and...
Ensure that all of the power connectors from you power supply are connected to your motherboard. There should be CPU power, general power, and power to your graphics card.
Mar 06, 2011 | Mercury P4VM800M7 Motherboard
I have a problem with my cpu ,its conected but the fan is not turning i conected the power ,to the mother board i got power to the dvd rw dvd player the hard drive plusthe extracter fan ,but my cpu fan...
please check the SMPS if youn have another new change it .or if you dont have smps another so open the smps and short the black +green wire and test the voltage bassically the four way connecting cable .disclosed the 24/20 pin socket.shibuda_4.jpgnow it same as before
please check the cpu fan and the connecttion is well connected.purchase and fit ..
hope it help you .please dont forgate to me.
Nov 28, 2010 | EliteGroup 661FX-M7 (661FXM7V11)...
What is the value of rectifier used for cooling fan in smps
its cheaper to buy a replacement fan because if you make a mistake during manufactuer then it may cause other problems,replacement fan in NZ about $30 and comes with warantee
Apr 27, 2010 | Dell (6F858) Cooling Fan
When i power on cpu fan start initially and then sop
try to change your fan proccesor or your power supply adapter for your CPU
Mar 12, 2010 | ASUS M2N68-AM SE2 Motherboard
Power turns off after a few seconds
Open your case, power up and then look at the CPU fan. If it spins normally, you may go to bios set up, look for Hardware Control, go to the fan subject and disable the function of watching CPU temperature or put it at the highest rank. If it does not help, you may think of RAM problem.
Aug 11, 2009 | Computers & Internet
Socket 478 3 GHz Intel CPU overheating
Simply open/unlock the clips and pull the heatsink off. Then you will need to remove the termal compound from both on top of the CPU and from the bottom of the heatsink. Papertowel + rubbing alcohol works well. Then you will need to re-apply thermal compound before reseating the heatsink/fan.
Jun 14, 2009 | Intel Socket 478 CPU COLLING FAN & HEAT...
Open Questions:
See all Gateway Solo Fan Assembly Questions
Gateway Solo Fan Assembly Logo
1,609 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
