It restarts the system
Bonerunsing
Many things can cause BSOD. If you can reply with the info from the BSOD this will help me see what is going on. The link below will show you the info I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Try booting into safe mode (tapping F8 while booting up) and select "Last Known Good Configuration". Then run a good virus scan.
If your geting blue screen when your starting up your PC
it mena there is a 2 problems
1 is your RAM is not working properly or RAM is gone i mean notworking
2 is if your RAM is working then you have problem with you HDD this two thing are not working propely then only your getting above screen
SOURCE: Blue screen corruption error
You might want to reseat your ram, Also See if you can get past the BSOD by hitting F8 and getting into Safe mode with Networking. Once there paste this into a Internet browser: http://msdl.microsoft.com/download/symbols/debuggers/dbg_x86_6.8.4.0.msi
Once downloaded and installed, click on
File>Symbol File Path > type "SRV*c:\debug_symbols*http://msdl.microsoft.com/download/symbols" and click OK. (nothing will happen)
File>Open Crash Dump>browse to c:\windows\minidump and select the file with the latest date. They are named in the mmddyy sequence.
Once the file is open wait and click on an option "!Analyze-V"
Then look for module name. This is the file causing the error.
Though lengthy, if done right this will certainly fix your issue.
