Question about Samsung ML 2010 Laser Printer
Paper stuck - Samsung ML2010
My pick-up roller in my Samsung printer rolls but it does not pick up the paper. It just pick it up halfway resulting in the paper being stuck every time i print
  • 150 Answers
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Posted on Apr 27, 2010
Needing help
Posted on May 04, 2013
Hi, i have a Brother MFC 7620N and 8 time out of 10 when i'm printing the paper get stuck and then i get this error obviously. My problem is that the paper always get stuck,do you know any idea...
Hi!
It is due to the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
May 31, 2011 | Brother Office Equipment & Supplies
PAPER JAM ML2010
May be it is your toner problem try toclesan it nd also change it.
If roblem still occurs then servece your printer and clean its pars with iso propile.
Sep 15, 2008 | Samsung ML 2010 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
The paper will not roll through to print.....it keeps catching right as it is starting to pull through. Nothing appears to be stuck...
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Nov 13, 2010 | Office Equipment & Supplies
Samsung ML2010 Printer does not receive the Paper
Make sure you have put enough paper in paper tray. Printer will not pull paper if not enough. (more than 10 sheets) hope it works. : )
Aug 10, 2009 | Samsung ML 2010 Laser Printer
My ML2010 printer turns on, takes paper, but stops halfway (blank
Hello sir; Replace paper pick up roller and feed roller.
Aug 02, 2009 | Office Equipment & Supplies
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Faulty paper pick-up & tracks down the length of the paper
This problem is caused by a slippery paper pick-up roller. Because the paper slips, it "arrives" too late in the printer mechanism resulting in image shift or paper jam.
You can see this gray rubber roller by removing the paper tray and the imaging unit and turn the printer on his back. Sometimes it helps to "clean" the roller with some sandpaper (take care to remove all small particles!) and/or clean it with some liquid (white spirit, thinner etc.)
Adri Hankel
Aug 07, 2008 | Samsung CLP 300 Laser Printer
Printer does not take paper from the tray
Try this Take out paper tray. Remove Toner cartridge Stand printer on its back so that you can see the pick up wheels/roller They should/could be on a removable rod/axle Pop it out and give a gentle rough up with a fine emery/nail board Re assemble - make sure the rod/axle is snapped it tight and correctly linked up re plug in - try it out. Failing that check the makers tech help on the web site.
May 13, 2007 | Samsung ML 2010 Laser Printer
I need help.
If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
Apr 04, 2007 | Lexmark Optra T614 Laser Printer
Samsung ML 2010 Laser Printer Logo
627 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
