Question about Maytag Atlantis MDE7400AY Electric Dryer
Need diagram on wiring new 4 prong plug, to take the place of 3 prong plug. thanks
  • Maytag Master
  • 1,606 Answers
Your dryer block has 3 terminals . On your cord , put the white in the center terminal of your dryer block , red and black on either side ( makes no difference ) , and the green to the ground screw or the screw which holds the cover plate on .
Posted on Apr 27, 2010
Testimonial: "to aasc, thank you very much for this info. my wife will be very happy when this gets hooked up, again thank you, sincerely Chris"
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Dryer has 3 prong plug,moved
Go to the following website to view pictures of how to hook up your four wires to the dryer.
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Posted on Dec 29, 2010
heatman101
  • 43501 Answers
SOURCE: moved and the new place
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 03, 2010
Need to wire a t30 242-5N with a 4 prong dryer cord help
on 4 prong,2 are hot 1 is common,1 is ground,,on 3 prong 2 are hot,1 is common ,you dont need ground,build your own plug
Wire Dryer Outlet
Sep 24, 2014 | Dryers
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 04, 2011 | Maytag Dryers
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
heatman101
Sep 03, 2010 | Dryers
I have a 1999 F250 Super Duty Lariat Super Cab 7.3L diesel.The wiring for the tow hitch is 4 prong flat with 3 extra wires.What was included from the factory and\r\nwhat do I need to pul camper with rv...
With 4 prong and 3 extra, that will give you what you need for 7 prong for towing RV. If your not too experienced in that area, a mechanic at any trailer place, or hitch installation place or who knows RV wiring, should be able to do it for you in about 1/2 hr. or less. Testing the wires from your truck for what they do as in right , left, stop, running/taillights, etc is about the hardest part, and the 7 prong usually comes with what terminal does what.48e2ffb.jpg
Jun 10, 2010 | 2002 Ford F250 Super Duty SuperCab
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
849 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
