Question about GE Refrigerators
GE GSS22JE went on the blink Fri nite. Nothing works on it except light inside. Any ideas of problem?
  • GE Master
  • 1,606 Answers
Unplug the refrig , and plug it back in , to reset the control board . If it continues to do nothing later , replace the main control board .
Posted on Apr 27, 2010
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Dec 20, 2010 | Friedrich Heating & Cooling
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Battery light is constantly on and battery went flat after radio and fan was on for long journey,could not start again except for jump start. charged the 2 batteries over nite and has kept charge for over...
the battery light is on to indicate to u that the cars alternator is not charging the battery, it doesn't mean the battery is bad, with no charge from the alternator the battery will quickly run flat.
Jun 30, 2009 | 1999 Toyota Avalon
When i press power nothing happens except the standby light just blinks and doesnt stop.
What is the make and model number of your set? I can help you but I need that info, So I know where to start.
Jan 23, 2008 | Televison & Video
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
