Question about Microwave Ovens
I have a ge gsh25jsta ss refrigerator. The main problem is that its not cooling enough, both freezer and fridge. Now ive been reading alot and i still have alot of questions. Things I've done so far: last night i vacuumed and cleaned dust behind and under the fridge but nothing. Now today i took everything out of the freezer and removed panel behind the freezer and the coils are covered with ice. What do i do from then? Thank you!!!
  • 2 more comments
  • trey08 Apr 27, 2010
    Thank you for responding so quickly! The model is a GE GSH25JSTA SS side by side refrigerator. Thank you again.
    On my way to blow dry. btw, this fridge is only 2 1/5 years old....brand new. Geez!!!
    Hey Phil,
    Sorry it took so long...i really had a small blowdryer. I located both the heater part and the terminator and both look fine. Now what do i do from then??? Did i mention this fridge is only 2 1/2 years old?( pissed ). Thank you!
    what do i do next????
    President:
  • 949 Answers
This is Phil and I will be assisting. It is apparent that you have a failure in the defrost cycle.
We need to remove the frost using hot water or a hair dryer and lots of towels, Unplug the refrigerator while doing this.
Next we will need to determine which component failed. I will tell you what to check in the next note I will send shortly, while I am composing that note I need you to recheck your model number from the tag that is located on the bottom rail that is visible when you open the fresh food door. The number I have here is not coming up as a refrigerator.
Thank you
Posted on Apr 27, 2010
  • Philip Apr 27, 2010
    Phil here again,
    There are 3 components that are used in the defrost cycle.
    #1 and most common to fail is the heat element. It is located on the bottom of those frosted up evaporator coils. It can be checked by an ohmmeter and should read between 10 and 100 ohms. It can also be inspected and sometimes see a break in it.
    #2 and fairly common is the defrost terminator sometime called a bi-metal or defrost thermostat. This component is located on the top of the coils and turns the heater off when the frost is gone. The ohm meter reading on this component should be 0 when cold, if it looks broken or bulging out it is bad.
    #3 and not as likely to fail is the defrost control this is either manual or electronic depending on your model and has an internal clock that counts the run time, every 8 -10 hours of running it turns off the cooling and starts the defrost cycle, it also will not let the defrost cycle run more than 25 minutes. If the other 2 parts are good this control is bad
    The heater part number is WR51X10055 and looks like this.
    The terminator is part number WR50X10065 and is a cylinder about the diameter of a quarter and in inch or so in height with 2 wires coming out of it.
    The defrost control is located in the back of the refrigerator is part number WR55X10942
The freezer is working but not the fridge fridge onm top freezer below I think it my be the thermostat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Microwave Ovens
Fridge is cold and freezer works but condensation dripping into main part of fridge - everything is getting mouldy - help?!
heatman101
Aug 31, 2011 | Microwave Ovens
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
heatman101
Aug 15, 2011 | Microwave Ovens
Fridge is not cooling. Freezer however is working totally fine
heatman101
Aug 06, 2011 | Microwave Ovens
Freezer is fine fridge will not stay cod
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 24, 2011 | Microwave Ovens
Fridge not working freezer ok
heatman101
Mar 27, 2011 | Microwave Ovens
The fridge isn't cooling the freezer works fine
heatman101
Feb 23, 2011 | Microwave Ovens
Fridge and freezer is stuck on defrost, what do I do?
Un plug it for a bit and then restart it....or a well placed whaap with your hand right by the timer may do it...
but sometimes it will not go and you will need to either manually turn it or get it replaced...
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 11, 2011 | GE Microwave Ovens
Fridge not working but freezer is ok!
heatman101
Oct 24, 2010 | Zanussi Microwave Ovens
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
