Question about Omron HBF-400 Fat Loss Monitor with Scale
How to connect HBF-206IT bluetooth enabled meter to PC? Please help!
  • lukorito2010 Apr 28, 2010
    Crazy. No solution so far
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Dec 29, 2014 | Samsung Radio Communications
How is ipod connected to bluetooth?
A Bluetooth transmitter (or radio) is hardware and is built into a Bluetooth-enabled product during the manufacture.of that device. A Bluetooth-enabled device can connect to another Bluetooth-enabled device to establish communication between them, but there is no Bluetooth network, the way there are wireless (WiFi) networks to which a WiFI-enabled device can connect. Bluetooth is short-distance (33 feet/10 meters between the Bluetooth devices) method of wireless communication.
Hope this helps.
Sep 07, 2014 | Apple 160 GB iPod Classic (Silver) +...
Bluetooth
fConnecting a Bluetooth device (Select models only)If your computer has an integrated Bluetooth adapter card, it can connect to and transfer data wirelessly to other Bluetooth enabled devices, such as notebook computers, PDAs and cell phones. You can transfer data between these devices without cables and up to 10 meters range in open space.Enabling Bluetooth communications on your computer1Slide the integrated wireless device switch from the button .2Press Fn + F5 to make configuration.Note: When using a high power consumption USB device such as USB ODD, use the external device's power adapter. Otherwise, the device may not be recognized, and system shut down may result.Note:The actual maximum range may vary due to interference and transmission barriers. To get the best possible connection speed, place the device as near your computer as possible.Notes:•When you do not need to use the Bluetooth function, turn it off to save battery power.•You need to pair the Bluetooth enabled device with your computer before you can transfer data between them. Read the documentation supplied with the Bluetooth enabled device for details on how to pair the device with your computer
Jun 22, 2013 | Lenovo G570 Notebook
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
I have an Acer laptop of Packard Bell and have Windows 7. I tried to connect the laptop and my Nokia 2680 with bluetooth. And the bluetooth of my Laptop gets switched on but, it doesn't connect with my...
Have you "enabled" the BlueTooth support on the Nokia?
Have you "enabled" the BlueTooth support on your laptop?
Do you get a prompt on the laptop (or the Nokia) requesting permission to connect to the BlueTooth network?
P.S. Look for a 'Fn Lock' key on the laptop. Press it to make all the other 'Fn' keys work.
Jun 15, 2011 | Computers & Internet
How to active E500's bluetooth?
Hi tran_dat_syc.
After researching all the information online, I found the steps to enable the Bluetooth Device in the Computer.
Please follow the below steps to enable the Bluetooth Device in the Computer:
1) From the Today screen, tap the iPAQ Wireless icon located
in the Navigation bar at the bottom of the screen.
2) On the iPAQ Wireless screen, tap the Bluetooth icon.
3) When Bluetooth is turned on, the Bluetooth LED on the front of your Pocket PC flashes blue.
4) To turn off Bluetooth, tap the Bluetooth icon again. When
Bluetooth is turned off, the Bluetooth LED turns off and no
incoming or outgoing Bluetooth connections are possible.
5) Battery Saving Tip: Turn Bluetooth off when you are not using it.
For more information regarding to the Bluetooth Device, please refer to the User Guide mentioned below:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00267893/c00267893.pdf
Please open the link above to view the User Guide.
Please refer to page 114 to 136 to view the detailed information to use the Bluetooth Device in the Computer.
Hope this helps.
Please feel free to ask for further questions.
Aug 21, 2010 | Computers & Internet
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
I don't know how can i use my computer's blue
We need to enable bluetooth and then we need to make the bluetooth your laptop and the other bluetooth device discoverable.
Now you will have to pair these devices and after pairing the devices and establishing the connection between the two devices, you will able to transfer files from one bluetooth device to another bluetooth device provided both of them are in less than 5 meter range.
You may try the steps in the below link:
http://gadgetguide.bluetooth.com/gadgetGuide.cfm?lpid=7357
If you have any trouble connecting to bluetooth, follow the steps in the below link:
http://notebook-solutions.blogspot.com/2009/06/bluetooth-of-my-laptop-will-not.html
Jun 14, 2009 | HP Pavilion dv7-1132nr Notebook PC
Connecting phone to pc
connecting you phone to your pc is quite easy to do.
all you have to have is:
pc with bluetooth capability( dongle)
celphone with bluetooth enabled
whenever your bluetooth dongle is attached to your pc, specially under windows XP, it is automatically configured to locate/find other bluetooth enabled devices under its radius.
when your phone is detected, you are asked to enter a pin to either receive data or send data to your pc.
having a bluetooth software will also lessen your frustration as bluetooth software have instructions or walkthroughs on how to do this.
cheers
Mar 23, 2008 | Cell Phones
Omron HBF-400 Fat Loss Monitor with Scale Logo
493 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
