Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore dishwasher model # 66513492K600--rinse agent isn,t dispensing.Customer doesn,t think it ever worked from day one.
  • Rene Matz Apr 29, 2010
    Detergent dispenser works okay on this model. Rinse agent dispenser isn,t working.Sears sent a
    new dispenser tank assembly but it didn,t solve the problem.I,m not sure on this model just how the
    electronic control does the dispensing. Maytag used wax motors--Kitchen aid has solenoids.
    Sears doesn,t have a good parts breakdown either. Rene
  • Rene Matz May 02, 2010
    Hi
    I haven,t heard back on this one.The detergent dispenser works okay on this dishwasher--its
    the rinse agent that seems to be not working.I,m not sure how this model works--theres no wax
    motors or solenoids.There is the drawbars by agent tank but not sure what controls them up by the
    electronic controller. Rene
  • 10,515 Answers
Most detergent dispenser doors are spring loaded. This means that the spring holding the door shut needs to be released by another component. The other component that will allow the dispenser door to open will either be the dishwasher's timer, a bi-metal switch, or a wax motor. If the detergent is caked or clumped in the dispenser, dishes will not get clean and dispenser door may not open. Causes of detergent caking and clumping in the dispenser:
  • Detergent Too Old
  • Incorrect Water Temperature
  • Overfilling Dispenser
  • Wet Dispenser
Solutions for detergent caking and clumping in the dispenser:
  • Detergent Too Old: Detergent absorbs moisture and the chemicals dissipate when exposed to air. Detergent may cake or clump and not dispense if it is too old. Do not use old detergent.
  • Incorrect Water Temperature: Hot water is necessary to dissolve detergent and ensure proper dispensing and cleaning. Be sure your water is hot enough to ensure the detergent dissolved properly.
  • Overfilling Dispenser: Can cause detergent to be packed when trying to close the dispenser door. This will cause the detergent to cake and clump in the dispenser and can prevent the dispenser door from opening. Do not overfill or pack detergent into the dispenser.
  • Wet Dispenser: Can cause detergent to bond and stick together or to stick in the dispenser preventing the dishes from getting clean or dispenser door from opening. Be sure the dispenser is dry before adding the detergent.
If none of this information helps you may have a faulty:
  • Timer
  • Bi-Metal Switch
  • Wax Motor
Helpful attachments:
Most detergent dispenser doors are spring loaded. This means that the spring holding the door shut needs to be released by another component. The other component that will allow the dispenser door to open will either be the dishwasher's timer, a bi-metal switch, or a wax motor. If the detergent is caked or clumped in the dispenser, dishes will not get clean and dispenser door may not open. _Causes of detergent caking and clumping in the dispenser_: *Detergent Too Old *Incorrect Water Temperature *Overfilling Dispenser *Wet Dispenser _Solutions for detergent caking and clumping in the dispenser_: *_Detergent Too Old_: Detergent absorbs moisture and the chemicals dissipate when exposed to air. Detergent may cake or clump and not dispense if it is too old. Do not use old detergent. *_Incorrect Water Temperature_: Hot water is necessary to dissolve detergent and ensure proper dispensing and cleaning. Be sure your water is hot enough to ensure the detergent dissolved properly. *_Overfilling Dispenser_: Can cause detergent to be packed when trying to close the dispenser door. This will cause the detergent to cake and clump in the dispenser and can prevent the dispenser door from opening. Do not overfill or pack detergent into the dispenser. *_Wet Dispenser_: Can cause detergent to bond and stick together or to stick in the dispenser preventing the dishes from getting clean or dispenser door from opening. Be sure the dispenser is dry before adding the detergent. _If none of this information helps you may have a faulty_: *Timer *Bi-Metal Switch
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 27, 2010
Dishwasher won't allow me to add rinse agent
Well, you don't have to rip the WHOLE machine apart, just the door! Usually takes about 6 to 8 screws (using a T15 torx screw driver). Depending on the model, you might only need to take off the lower half of the door (all below the control console), or you might have to take out all the door screws. Then remove the detergent dispenser (6 more screws, this time a 3/16" hex head). Then you can remove the wires to it (unplug the DW first!), and pop the dispenser out. Take it over to your sink and turn it upside down and shake it. You might try running hot water over the inlet port to clear up any dried-up residue. You will probably get some water into areas you don't want (like the coil and connectors), but when you are done, you can use a can of compressed air (or "duster" cans) to blow the water out. If that doesn't work, then you will probably need to replace the whole dispenser; but hey, you're already halfway there - you've removed the old dispenser. You can buy new dispensers at SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com or AppliancePartsPros.com.
Mar 08, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Rinse agent not dispensing
Hi I will try and explain how it works , if you look at the cover for the rinse it has small slots on it as the water splashes around inside it and this makes the agent come out if this cover is blocked or dirty it won't let any come out .. I always tell ever one to use less soap then the box says to use and always use a premium type soap , not the wal-mart brand , think about t if you have to clean your dishes after they are washed then why have a dishwasher ? I always say that is what teenagers are for
Dec 10, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Older dishwasher is leaving a white film on the glasses. Have checked the water (125 at the sink) cut down on detergent, used "dishwasher cleaner" a couple of times. Any Ideas? It is a Kenmore...
If your model has a JETDRY rinse agent dispenser be sure to use it..if it does not have that dispenser and just only the detergent dispenser use the JETDRY in the dry version that is in a little basket and hangs on the upper rack.
GENE
Aug 31, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
yes it will foam up unlike you have never seen before
by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
White film left on the dishes after going through the dishwasher. Why?
Too much rinse agent. If you are using powder or gel, set pointer knob on rinse agent dispenser to a lower setting. If you were using the tablets, they have rinse agent built into them, and the additional rinse agent from the dispenser equals a double dose, so the film shows up. Stop using tablets until liquid rinse agent dispenser is empty.
Apr 14, 2011 | GE Dishwashers
Rinsing agent dispenser empties too quickly
has the seal ring fallen away? is the flap shutting properly/ try setting it to a lower numbered setting.
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore dishwasher model 665
rinse aid generally dispenses automatically in cycle, very small amount every time. why do you think its not dispensing?
Feb 22, 2008 | Dishwashers
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
124 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
