Question about RTO Cal Torpedo Pump 7500 Gph
Torpedo pump...I have one when I plug it in...it trips breaker
Torpedo pump...I have one when I plug it in...it trips the breaker.. Cord looks great...pump looks great...only 2-3 years old. Never been out of water while running. Can it be left outside in winter if housing is drained?? Why would it trip?
  • Frod May 01, 2010
    I called the factory....they said...Its not going to work for there is no replacement parts for it.
    For grins..I dove into the pump...Pulled the seal and it was full of water. The motor was toast and it stunk up the entire garage.
    Anyway...new pump on order.
Same problem. Runs great until I put it in the water...kinda important for a submersible pump. It trips the GFCI. I took it apart and put silicon sealant around wire entry and even ran a bead along the o ring. Not sure if a new o ring is available...local hardware did not have that size. Bottom line... did not work. Frustrating cuz pump starts and runs fine until in the water. Running water in the intake does not trip the outlet. Pump is only 3 years old.
Posted on May 30, 2013
I had the exact same issue. I left mine out for the winter and when I plug it in, the breaker trips. My warranty was up so my friend took it apart. The seal had broken alowing water to leak into the bottom the pump where the wires connect to top of motor. This is supposed to be water free and is protected by several seals.
I am currenlty trying to put sealant where the cord goes into unit to stop water from going in. I will let you know how that works.
One tip my friend recommeded is to make sure there is no stress on the cord as it appears this seal is weak and and kind of stress will break it. hope this helps -- Rob
Posted on Apr 30, 2010
  • Patti Hall Nov 09, 2011
    I am now having the same issue... It was working great, but I unplugged it to clean out the pond for fall clean out... When I was done, I plugged it back in... pump works for about 45 seconds then tris the breaker... I have replaced the outlet and the plug itself, checked all the wiring, and still the same issue... I have never had any problems with my pond systems until now... I have no clue what to do now except to take it apart and check for internal problems... if anyone has had these issues and resolved them, please repost, I can not afford another 10000 gallon pump right now... And this pond is a memorial to my son, who I recently lost...
I have the same problem. This is the second T7500 that operated just fine on a circuit breaker for about 2 1/2 to 3 years and then began to trip the circuit breaker. I believe (although I am not an electrician) that the unit develops an internal short at about 2 1/2 years, which is internal, e.g. not cause by any leak. I say that because the unit will actually run for another 1-2 years on a circuit that does not have a circuit breaker outlet. That is of course a dangerous proposition, and which the instructions strictly prohibit, however, that tells me that there is no internal water leak in the unit causing the short. The short is from something else. Comments?
Posted on Apr 27, 2015
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
Jul 25, 2014 | Rule 1800 H53SP-24 Swimming Pool Cover...
When turned on it just humms and blows the 15 amp breaker in the panel
you have a dead short! Check the compressor you are plugging in. Check cord for damage to wires. If cord looks good and compressor is in good shape where you are plugging in is overloading circuit and tripping breaker. Does the breaker hold for any period of time when you reset it?
Jan 19, 2012 | Air Tools & Compressors
Hello, I have a WGFP-15 pump in a backyard water feature. It has run fine for 4 years. Just yesterday, it shut off and every time I plug it in, it trips the circuit breaker. When I connect it to an...
Yes, you have a short! It is probably between your neutral and ground. That is why your GFCI is tripping on your outside outlets, but won't trip the non-GFCI breaker on the inside.
Jul 07, 2011 | Little Giant Plumbing
Lights and burns for just a little while and then trips reset breaker
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 30, 2010 | All-Pro Forced Air Kerosene Space Heater...
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
Rv electrical question
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Pump is not running, or it keep tripped the circuit breaker
If it hums, and there is no water moving then you could have a bad starting capacitor, but if the motor is old, and has been running louder than usual in the recent months then it could be that the motor needs to be replaced.
Apr 05, 2009 | RTO Cal Torpedo Pump 7500 Gph
RTO Cal Torpedo Pump 7500 Gph Logo
558 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
