How to remove write protect on my usb flash drive
My mp3 player does'nt want to accept files or delete them.
When i send files to it,it says it is write protected
Sansa Express SanDisk 1.0 GB
Product Code: BB0704UIB
Hi Guys, urgent solution required,
I use three different USB portable tools, storage drives, flash drives & memory sticks, never had the problem before but I now cannot delete, remove, copy, add or transfer files etc, I experience exactly the same situation where a message box indicates that the device is write protected pls remove or use another disc, cant find a solution, there are no switches, what should I do, I tried to find the solution through my computor device mananger but there is nothing there to indicate a problem, Please help, I need these tools for my work.
  • 2 more comments
  • maguip Mar 25, 2008
    problem exists on all my portable drives and memory sticks, it is not confined to just the one.
  • maguip Apr 02, 2008
    hi, I do not use an mp3 player, my concerns are with my portable drivers, none of them have lock/unlock facility, the problem I believe is with the laptop as all the portable drivers and flash drives are having the same problem.
    what should I look at on the laptop, where should I go.? as I wrote I cannot copy, delete transfer etc from any of my drivers, however all drivers work on my desk top without any problem.
  • maguip Apr 03, 2008
    I have tried ADMIN login and still have the same reponse, I can open everything on my FREECOM and WD Hdrives but I cant rename,delete etc as I have mentioned before. Completely perplexed, just dont know what to do????????
    No discs involved here, only portable drives, no lock/unlocks, works OK on my desktop no problems, can do everything, cant do anything on my laptop, read only it seems, no delete, no rename, no transfer etc, always "write protection on" pls remove or use another drive box displayed. cant remove the write protection??????
    Genius:
  • 3,422 Answers
Here is the solution to your problem:
On your memory stick, there is a "Lock/Unlock" slide bar on the opposite end of it. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected.
There is a same lock in the USB flash drive.
Now coming to the Mp3 player.Make sure that your mp3 is not in the "pause" mode. I must have put in on pause my mistake and I wasn't able to do anything with it, play, copy music or delete. All I did was push my pause/play button once to get it to play mode and have had no problems. It was such an easy fix if you don't have the 'switch' on the side.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 30, 2008
  • Priya darshan Apr 03, 2008
    Hi again,
    Just visit the below two links they will help you fixing the problem.
    1)Click HERE
    2)Click HERE
    Goodluck,
    Please don't forget to accept the solutions..
  • 13,433 Answers
I will help you, please confirm is this a mp3 player or a usb flash drive?
  • Ekse Apr 02, 2008
    All USB memorys and mp3 players?
    Thanks, Il get back to you soon!!
  • Ekse Apr 02, 2008
    do the disks works ok in all other computers?
    Guru:
  • 1,894 Answers
This is due to some kind of virus ibn your system
  • dewan nafees ahmed Mar 30, 2008
    to comfirm this try those devices in another system of same kind and just confirm that these drives work with other system or not,.
    if they work with other system then there problem with your side.
    this may be some virus that is not allowing you to transfer data trough USB ports.
    else this may be some problem in *********** board which is not able to transfer data trough your USB port.
    else may be your OS problem.
    just isolate the problem first. then you can solve it with ease.
  • dewan nafees ahmed Apr 02, 2008
    ok then try a different login.. preferably ADMIN login by booting into safe mode..
    then try to use the drives..
    even if it is not working then try reinstalling your OS if you are comfortable with that..
  • 790 Answers
Hello ,
Reset ur player my pressing the reset pin on the side of ur player and try connecting it again
Posted on Mar 24, 2008
    President:
  • 1,944 Answers
Are you able to format the player?
  • Damen Wong
    Damen Wong Mar 24, 2008
    The player shows up as removable storage when connected to the PC...correct?
  • Damen Wong
    Damen Wong Mar 28, 2008
    If this happens to all devices then there is a problem with either your computer/USB cable/or USB port. Did you try another cable and USB port?
There should be a very small slide switch along the edge of the card. Sliding this one way will lock (write protect) or unlock the card.
Mar 28, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
your mp3 is damaged im afraid, no other way around it
sorry
Nov 02, 2008 | Samsung YP-U3 MP3 Player
Make sure the hold button isn't on. It's as simple as that.
Sep 09, 2008 | SanDisk Sansa Clip MP3 Player
what is the type of your mp3 player ?
it need anew firmware,
Aug 12, 2008 | Kingston Technologies 512MB DataTraveler I...
I found out that i just had to move the switch on the micro SD card from lock to unlock.
Jul 05, 2008 | Motorola Mobility i880 Cellular Phone
There is a software on internet, it is FREE of charge, it is called unlocker, it's a simple installation that lets you delete, rename, move any file/folder, just right-click the desired file/folder, go to"Unlocker" the image is a wand, and select the option you want.. works for me. good luck. hope this helps
Jun 02, 2008 | Creative Labs Zen Digital Media Player
how to remove write protected on my usb flash drive and i have mp3; when plugin into the usb hub it shows a problem occured during installation
May 04, 2008 | Electronics - Others
bulshit atttttttttttttttttttttttttttttttttttttacsahcvxc
vdfbfdbvbvfdbgfdfgdfgdfgdfg
Dec 30, 2007 | BUSlink MUSICA MP3-PBD1G MP3 Player
Make sure your mp3 "HOLD" option is not on!
Its really as simple as that. The hold button 'protects' the files.
Nov 24, 2007 | Audio Players & Recorders
how can i delete the files on my flash drive
Nov 15, 2007 | Video Game Consoles & Games
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
