Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig side by side refridge side on 7 not keeping cold freezer side is fine
  • rc4546 Apr 27, 2010
    i noticed that on the top side of the refig side there is a door that seems to be activated by a sensor the door is closed yet its not cold in the frig i have the setting on 7 should be real cold
  • Dan Webster
    Dan Webster May 11, 2010
    Look for frost on the backside of the freezer section. That is s good indication of a defrost problem. No timer on this model, defrost determination is fancy but guess what? They still use the defrost heater and terminator thermostat from back in the day.
  • GE Master
  • 8,220 Answers
That's called a damper. Probably faulty
Posted on Apr 27, 2010
Testimonial: "Great job Thank you Sir"
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The refridg part of my ge side by side stopped working but the freezer still works
HI,CHECK IF THE EVAP MOTOR IS WORKING,IF MOTOR IS WORKING ,PROBABLY YOUR REFRIG HAVE A BAD CONTROL BOARD CHECK BOTH OR REPLACED BOTH ALSO CHECK AIRFLOW CONTROL DAMPER..
Jul 05, 2011 | GE Profile PSW26P Stainless Steel Side by...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
G E side by side refrig . freezer cold but
you have a defrost system problem timer or heater or bimetal tst could have a electronic defrost timer
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Jun 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
262 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
