Question about Kenwood VR-7070 Receiver
When adjusting the sound, we lose sound completely. The volume knob on the receiver does nothing. If we play with buttons on the receiver, sometimes it comes back. The second last time it happened, I shut everything off. When my wife turned it on 2 days later, everything worked until she adjusted the sound with the remote. Now we have no sound. Do we need a new receiver?
    Champion:
  • 287 Answers
I would try and clean your switches and controls before giving up on the receiver. use de-ox-id contact cleaner on the volume control and switches. Larry's Electronics
Posted on Apr 28, 2010
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
Volume control on teac crh250
Make sure the volume knob is tightened to the volume potentiometer shaft via the set screw on the knob itself.
Jun 12, 2016 | Teac Audio Players & Recorders
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
My reciever volume cuts in and out and crackles when adjusting
You can CLEAN / LUBRICATEthe volume control know with a CONTACT/CONTROL cleaner, I use a product from Radio Shack, this works wonders on drum type electo mechanical devices which are basically volume control knobs, easy to do, just remove the round knob and spray into the openings with the small tube attached, and rotate in both directions, be sure to unplug the unit first, on a few occasions it is best to remove the front panel to acheive better coverage to the rheostat type volume body, anyway it always cures the crackling and distorting sound, I would give this a try before replacing the part.
Feb 14, 2009 | Technics Audio Players & Recorders
CD volume
Select the source to adjust
Press the [SRC] button.
2 Enter Audio Control mode
Press the Control knob.
3 Select the Audio item to adjust
4 Adjust the Audio item
Turn the Control knob.
S Exit Audio Control mode
Press any button.
Press a button other than the Control knob or ...
button.
1 Select the Basic Audio item
For how to select Basic Audio items, see <Audio
Control> (page 6).
2 Enter Detail adjustment mode of Audio
Control
Press the Control knob for at least 1 second.
3 Select the Detail Audio item to adjust
4 Adjust the Detail Audio item
S Exit the Detail Audio Control mode
• When you set the Bass Extend to ON, low frequency
response is extended by 20%.
• You can exit the Audio Control mode at anytime by
pressing any button except for Control knob or ~
button.
http://akamaipix.crutchfield.com/Manuals/113/113MP338.PDF
page 6 and 7
May 06, 2008 | Car Audio & Video
Lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Apr 22, 2008 | Car Audio & Video
Open Questions:
Kenwood VR-7070 Receiver Logo
118 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
