Question about Port Designs Arkview USB 2.0 10/100 Ethernet USB 2.0 Print Server (1 Port) PC/MAC (PS-2153) Print Server
Arkview USB 2.0 networking usb server -- corrupt ip address and mac address how can I reflash the firmware so I can use the item again. it is not being recognized by the DHCP in order to get a local ip address mac address shows 11 22 33 44 etc instead of factory one. I can get into the settings and I can enter them but the unit wont accept the new settings help?
  • 476 Answers
Replace it and save your self a headache
Posted on Apr 27, 2010
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Tip
Configure PS121 with MAC OS X
Configure NETGEAR PS121 print server with MAC OS 10.4.X and may work for other version of MAC OS X
Please sure that the printer is working in direct connection with the computer.
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Open the System Preferences
Click on “Print and Fax” icon
Click on the “+” icon to add a new printer
Click on the “IP Printer” icon
Select “Line Printer Daemon – LPD”
1. In the Address field, enter the IP address of the PS121
2. In the Queue field, enter L1
3. In the Name field, enter L1
4. Select the printer manufacturer from the pull down
5. Select the printer model from the scroll box
6. Click Add
a. Click once on L1 to select it
b. Click on Printer Setup
Click on the “Installable Options” pulldown menu and select “Name & Location”
1. Change Printer Name to IP address of PS121
2. Change Location to: IP_.ip of PS121
3. Click on Apply Changes
The Macintosh is now ready to print.
on Mar 18, 2010 | NetGear PS121 Print Server
My printer is displaying "Print Server Down". How can I fix this error?
this printer has a usb interface can you see an axis 1650 usb to ethernet server box attached to the usb cable that is attached to the printer ?
would check power to the usb to ethernet server box see photo inserted of what it looks like !
Maybe the power has been disconnected or the ac-dc adapter has gone faulty .
If it has power may be try removing power from it for 20 seconds and then re plug in and then test by printing to printer.
check print server has valid ip address.
also check dhcp server on network has not got printer servers ip address in its lease range. check also that printer server's ip address is static and not being set automatically.
if printer server is ip address try going to dos prompt on p.c. and type in ping {ip address of server} eg c:> ping 192.168.0.2
press Enter key
should get a reply 4 times
Oct 26, 2015 | Canon LASER SHOT LBP-2900 Printer
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Port Designs Arkview USB 2.0 10/100 Ethernet USB 2.0 Print Server (1 Port) PC/MAC (PS-2153) Print Server Logo
966 people viewed this question
Top Port Designs Computers & Internet Experts
Martin Murray
Prashant M
Prashant M
Jax Planet
Jax Planet
Are you a Port Designs Computer and Internet Expert? Answer questions, earn points and help others
