Question about Bose LifeStyle 50 System
Cannot get all the speakers to play
The only jack that works under the subwoofer for the other speakers is the front left, when i take that speaker out and plug in the other speakers into that jack thespeaker that goes in that jack works any ideas :).
  • 9 Answers
SOURCE: Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Posted on Jun 07, 2009
  • 133 Answers
SOURCE: left speaker not working
Some possibilities (your description suggests that both speakers are okay):
- a desoldered pin on the left speaker connector inside your unit or a damaged connector
- a fault or a desoldered contact on one or more components in the left channel's preamp or final amp section, or at the power supply section for that channel, also check speaker protector fuses on the board, if there are any
- a bad connector contact somewhere on the board, possibly an oxydized contact, desoldered pin or a (partially) disconnected/broken wire.
Anyway, these are just a few suggestions, but i hope they can help somewhat...
regards
3rq8 (Triarcuate)
Posted on Jul 27, 2009
pra0099
  • 153 Answers
SOURCE: bose lifestyle 28 system, only one speaker works
check the wiring and the system settings
Posted on Sep 18, 2009
  • 222 Answers
SOURCE: only one speaker is working
Try switching your speaker's if your dead speaker work's on your good line then something's wrong with your Amplifier.
Posted on Jun 13, 2010
  • 12 Answers
SOURCE: my system is 8 yrs old. the center channel
Sign up here for lots of goos info:
http://homeavi.pro-forums.com/
Posted on Jun 21, 2010
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I cannot seem to get the driver working on my new computer which has windows 7 currently. Are the two compatible?
Are we looking at this same computers? Since when do you require drivers for speakers?!? Speakers are dumb devices (yes, this is correct name for passive computer devices) and do not require any drivers in any computer or operating system with sound capability! Computer speakers are compatible with any copmuter in the world and any operating system which generate sound!
These speakers are qualified as 5.1, that meant that these speakers will have front bass, front centre speaker, front left and right speaker and rear left and right speaker, in total six speakers.
Please follow this advice and you will have joy of surround sound.
1. Mount your subwoofer in front centre, below your knee level at the distance of about 2 of your hights
2. Mount your centre speaker in the centre on your head/hight level or slightly above at same distance as subwoofer or slightly closer.
3. Mount left front speaker about 45degree from your centre line to the left and right same distance to your right, on the level of your head while you are listening to the music, distance from you slightly closer (about 1/2 your hight) than your centre speaker.
4. Mount your rear left and right speakers at same or slightly greater distance as front left and right speaker. these should be at same or slightly higher level as front speakers.
5. Triple 3.5mm jack is going to your computer output and your speakers (incidently, your subwoofer servers as junction box, amplifier and mixer).
6. Connect speakers to they respective jacks.
7. Turn power on speakers all way down
8. Connect power to the speakers and switch it on
9. Play some music on your computer, output on full, music recommended will be some classic, like bach or similar
10. Put your hand in front of subwoofer and turn bass till you feel vibration
11. Turn sound till you hear it well
12. Turn sound on the computer down till about 70% - 80%
13. Turn on sound on your speakers till desired level and enjoy the experience!
If you have still some problems, these can be then related to the drivers installed on your computer, please check therefore what motherboard do you have, if there is proper sound drivers installed. If not, go to the site of our motherboard/sound card manufacturer and install relevant drivers.
Please do not hesitate to ask me if you have any addtional problem related to this particular issue.
Aug 06, 2010 | Creative Labs Inspire T5400 Computer...
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Left Channel does not work. Subwoofer and Right Channel work fine. The plug needs to be plugged into the brown jack on the front of the computer to work at all.
Sort of sounds like there's a PC in the mix.
Can you swap the left and right speakers to isolate the speaker from the source as the problem?
Have you tried switching the various plugs around to isolate if anything comes out to the Left Channel, ever or if any other speaker plugged in as the Left works at all? Turn the volume down and bring it up slowly at first because if you send Subwoofer programming to a speaker not designed for it you may damage it.
If nothing works when plugged in as the Left speaker, maybe the sound card is the problem. Resubmit a question with the source or the PC as the problem
Nov 28, 2009 | Altec Lansing VS4121 Speaker
HOW DO I PLUG UP THE SUBWOOFER TO AMPLIFIER
On the back of the amp, there should be a jack with the name "SUBWOOFER PRE OUT". It is a standard RCA jack, but it only puts out a line output, meaning only self-powered subwoofers will work with it. Usually, if the subwoofer does not have an amp, it will have 2 imputs and 2 outputs. You plug the two left and right inputs into the front speaker jack on the amp, and then plug the front speakers into the left and right amp on the subwoofer.
Jun 17, 2009 | Audio Players & Recorders
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
No sound out of centre speaker
Make sure your amp is set to a channel which plays on all speakers (5.1).
If you have the amp set to "Stereo", it is only the frontspeakers and subwoofer which play sound.
Oct 14, 2008 | Audio Players & Recorders
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Bose LifeStyle 50 System Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
