Question about GE Nautilus 24" Built-in Dishwasher
How can I force drain the dishwasher - GE Nautilus 24" Built-in Dishwasher
  • 06GP3800 May 11, 2010
    Have you tried to turn the dial to the end of the wash cycle?
Water not drain bottom
Do one thing apply a good force of water in that what ever would be there it would be drain out with a force of water.
here
Nov 21, 2013 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bosch shx33a starts, fills, then stops. Drains OK when forced to end cycle.
I know this may sound very silly but i had the same problem with mine and all i had to do was pull it out a bit as the drainage pipe at the back was only slightly sqashed against the cupboard but it does matter
Sep 13, 2012 | Bosch 24 in. SHX33A05 Stainless Steel...
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Nov 21, 2009 | Dishwashers
Won't drain
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Nov 06, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
There is water in the bottom of the dishwasher. How do I locate the drain hose? Which one is it underneath the dishwasher?
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain I have taken out the basket and cleaned it I have used a garden hose to force water through the SUMP INLET but it still won't drain by itself.
If it does not drain itself when you push Reset, then the drain pump is most likely bad. The whole unit will have to be pulled out to check or replace it.
Oct 17, 2009 | GE GLD5800L Dishwasher
Water not draining out of dishwasher
Sep 06, 2009 | Frigidaire Dishwashers
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
MY DISHWASHER IS CLOGGED UP. HOW TO DRAIN?
You could try to remove the flexable hose that connects from the dishwasher to the drain pipe (remove drain pipe end) and try to force water into the dishwasher
Aug 08, 2009 | Kenmore Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
416 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
