Question about Toshiba 32A14 TV
I have white horizontal lines about 2 inches at top of my tv
I have a 32 " Toshiba 32A14 model Nov 2004 tv the last year or more white horizontal lines across top of screen and black bar at very top so no picture the top one inch of screen then the bars for about 2 inches below that..have little money can I buy the part myself, I live in Ontario, canada..what is wrong, what part I need and how to fix this?
  • Toshiba Master
  • 1,229 Answers
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Posted on Apr 27, 2010
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
2 in. band at the top of my Toshiba 32" Tv is distorted. No adjustments worked. Thought it was the change to dtv, but this is the only tv in the house that's affected.
well is the band white or black and clapsing it may be in the vertical curcit also does it do it w/out dtv converter box hook it back up the way that it was see what happens sorry
Apr 03, 2009 | Toshiba 32A14 TV
White horizontal lines on top of the screen otherwise picture OK.
This is a symptom of what is generally a leaky or open filter capacitor in the vertical sweep circuit. Vertical foldover, where the image actually is reflected upside down an inch or so into the top of the picture, is common in this problem. There is an IC that controls the signal and sometimes it needs to be replaced, but more often it's one of the filter capacitors nearby. Any competent technician can fix this problem and the capacitors only cost $2-3 or so if you can find the correct value at Radio Shack (that's if you pay full retail for them). A good service tech will probably have these on hand. Testing them is easiest with what's called an ESR meter (stands for Equivalent Series Resistance) and the better ones don't require you to unsolder them from the circuit board before testing. The most expensive part of this repair is going to be the technician's labor. They're good TV's, this is just a problem common to most TV's in general - mostly due to aging of the capacitors from years of heat. A higher quality replacement capacitor will solve the problem for the life of the set.
Mar 28, 2009 | Toshiba 32A14 TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Horizontal lines on top fourth of picture
the guy who sold it to you has the same white lines on his forehead.emagine that. wallmart is real cheap.
Jan 04, 2008 | Sanyo DS32920 32" TV
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Toshiba 32A14 TV Logo
384 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
