Question about Brother DCP 130C All-In-One InkJet Printer
Clean uneable 46 brother dcp 130c printer what is this/
  • 4,041 Answers
Hi there you can try
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Clean unable 46 on brother DCP-130C
HI,
On most Brother MFC machines it is the buttons: function, *, 2, 8, 6, 4, hit the buttons within 2 seconds and in order like push function than push *, than push 2. and on within 2 seconds.
If you do this right Maintenance should show up in the display. Now press 01 which clears all memory and puts the machine back to factory default. Realize that all addresses in the fax and cover page will be gone and you will need to set it up again. Now hit 99 to leave maintenance mode and try the machine.
Jul 23, 2011 | Brother DCP 130C All-In-One InkJet Printer
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
How to solve the clean unable 46error of a BRother dcp-130c printer.
Clean unable 46 means you need a new flushing box. It's where the ink goes when it cleans the printhead, and yours is full. You need a shop to replace it.
Jul 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Printer installation
Hi -You can download the driver from the following link:
DCP-130C
Good Luck!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
have cleaned tanks , need to reset counter? any help as to how?
Jun 22, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
