Question about GE Spacemaker JVM1640SJ Microwave Oven
My microwave, GE Spacemaker, stopped heating. What do I need and
My microwave stopped heating. What do I need and what would be the approximate cost?
  • 254 Answers
Please rate ?
some models had a five year parts warranty on the magnetron those are usally 80-160 dollars. if not in warranty then u would be charged that and probably a service call around 80 dollars and prob labor to install it which would be around 30 dollars because to inspect it and install the part u must remove the micro if this is a over the range hangin micro.
this is the worst case scenarion it always could be an internal fuse, diode, or thermostat on some, but wont be known until inspected by technician, i know some local shops that service these for cheaper if u can remove the unit and bring it to thier shop.. Also depends how old it is it might be better of to buy a new one if your gettin near 7-10 years
hope this helps good day mate
Posted on Apr 27, 2010
Clicking sound ge microwave spacemaker xl1400
There should be a buzzer sound that is made by a piezo. If it isn't sounding correctly then it must have a bad solder joint on it, or the ic that controls it is malfunctioning
Dec 01, 2013 | GE Microwave Ovens
G.E. spacemaker microwave stopped heating,made louder than normal sound,smelled odd.
The magnetron has failed, "heats food" to repair the unit will approach the cost of a new microwave oven.
May 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My spacemaker microwave Model JVM164WB has no heat
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Mar 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
131 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
