Question about HP 1040 Plain Paper Inkjet Fax
Need to set up my fax machine in 24 hour format.Could you please tell me the exact time right now.
    President:
  • 3,085 Answers
You can't, on that fax machine.
Posted on Apr 27, 2010
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
5 Enter the time in 24-Hour format. Press Menu/Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
How to set the date and the time in brother fax mfc-8220? what's the steps?
Your MFC displays the date and time and if you set up the Station ID
it prints on every fax you send. If there is a power failure, you may
have to reset the date and time. All other settings will not be affected.
1 Press Menu, 0, 2.
Press Set.
Press Set.
Press Set.
Press Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the MFC is in
Standby mode.
thx, if this helps please rate :)
Jan 27, 2011 | Brother MFC-8220 Fax
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
To change clock format from 24 hours to am pm for htc p3400i
Not a problem, this will be under the main seetings menu.
But I havn'y used it so can't tell you exact so, to know the exact you have to have a look into the user manual.
If you have the hard copy then read it, otherwise get it free from here.
Hopefully this will help you.
Kindly do Rate!
Regards.
Jul 18, 2009 | HTC P3300 Smartphone
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
Wrong time printed on fax
  1. From the machine, press the [Menu] button until 'Machine Setup' appears on the top line of the display.
  2. Press the right arrow button until 'Date & Time' is displayed on the bottom line, then press [Enter].
    1. Enter the correct time and date using the numeric keypad. By default, the machine clock mode is set to 12-hour format; however, this can be changed to a 24-hour format (see the change the clock mode section below).
    2. Month = 01 ~ 12
      Day = 01 ~ 31
      Year = requires four digits
      Hour = 01 ~ 12 (12-hour mode)
      00 ~ 23 (24-hour mode)
      Minute = 00 ~ 59
    Note: To select 'AM' or 'PM' for a 12-hour format, press the * or # button or any number button.
    1. Once the correct date and time has been entered, press [Enter].
    2. Press the [Stop / Clear] button to return the machine to Standby mode
    Feb 19, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
    The digital clock seems to be set to 24 hr insted of 12 hr time
    No Problem here ya go
    To change the clock to 24-hour format:
    1. Press and hold the CANCEL and Delay
    pads for three seconds.
    2. Press the More+ or Less - pad to select
    12 or 24 hour.
    Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
    Xerox workcentre Pro 575 How do I change the time of day setting
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
      [01-31-2000]
    2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
      1. MM-DD-YYYY
      2. DD-MM-YYYY
      3. YYYY-MM-DD
    3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
      1. Numeric: displays the month with a number
      2. Name: displays an abbreviated month name.
    4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
      1. 24 hour
      2. 12 hour
    5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
      10:30 pm (or 22:30 pm if you chose the 24 hour format).
    6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
    7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
    Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
    Time
    This should take care of it for you.
    NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
    1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
    2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
    3. Press the [Start / Enter] button.
    4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
      NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
    5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
    6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
    7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
    Dec 13, 2007 | Office Equipment & Supplies
    HP 1040 Plain Paper Inkjet Fax Logo
    26 people viewed this question
    Seeker5211
    Seeker5211
