Zenith sound issues
I have a somewhat older Zenith TV and my daughter got hold of the remote a few days ago and now the sound is off and i have tried everything to get it back on. I know the speakers still work because of the static i hear when i see snow. Any ideas?
  • kiryoku88 Apr 28, 2010
    I have tried that, along with changing and resetting every option that my remote will let me. If it were the mute button, I would not have posted this problem. Thank you though
  • 901 Answers
Check the sound mute button in your remote and press it and watch the TV menu.
Posted on Apr 27, 2010
  • Ambari Apr 28, 2010
    This mute signal,has to be tested at pin level in the main IC. Then the sound IC has to be checked.
    If the video also missing it is a tuner problem! It may be AGC voltage and so on. If you can trouble shoot your self you can check all these points using schematic.
    If you have DVD try. If sound is OK , the probable trouble in Tuner circuit area. You can arrive at a conclusion after this.
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Apr 24, 2015 | Zenith Televison & Video
    Tip
    Reset your TV Lamp--------> ZENITH <----------------
    If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter…Otherwise you may get an annoying reminder every few days if you’re surpassed the predetermined hour mark.
    Ensure the TV is powered on.
    1. Press and hold the MENU button on the TV
    2. Press and hold the MENU button on your REMOTE (hold both these until the service menu pops up 5-10 secs max.)
    3. Let go of the REMOTE button first, then release the button on the TV
    4. Press and hold the ENTER (or OK) button on the TV
    5. Press and hold the MUTE button on the REMOTE(hold both until the LAMP LIFE HOURS appears on the screen)
    6. Let go of the REMOTE button first, then release the button on the TV We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference
    7. To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
    For certain models, you might have to tweak these steps slightly… offer your inputs!
    on Mar 24, 2010 | Televison & Video
    Popping sound on my toshiba 32" flat screen
    pls. cheked
    1. suond ic input supplay voltage (ic B+ voltage regestance 1 ohm.
    and capacetar 2200um/35v replace)
    Oct 04, 2009 | Zenith R57W46 57" Rear Projection...
    I have an older tv remote that requres a 3 didgit code the tv is a zenith and so is the remote
    here is how you retrive the code...make sure tv is on
    Step1..press and hold code search button till light comes on then release
    Step2..press the TV button once
    Step 3.point the remote at TV and press and release the power button while pointing at TV((you may have to keep pressing the power button several times)) once Tv shuts off hit ENTER
    Step4..Press TV button on remote and there you go!!
    GOOD LUCK!!!
    May 09, 2009 | Zenith DBZN-311 Remote Control
    Replacing lamp
    try this to see if it works!
    We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference
    Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
    I need a code for an older zenith tv 13"
    Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
    1)hold down tv button next to sat button in top left corner
    2) when all buttons illuminate press 500 into remote
    3)press pound sign
    4)Hello, please help..
    5)hold town tv button again.
    6)when all buttons illuminate press big red power button
    7)press up arrow once a second until tv shuts off
    8)press # pound sign
    9)try to turn tv back on w/ big red power button
    10)if tv doesnt turn back on try again from step 2 but use down arrow instead
    Aug 01, 2008 | DISH Network IR Remote Control
    Loud popping and decrease in volume
    I'm guessing power supply problems fluctuating, or main control board.
    Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
    Zenith Lamp Light on
    When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
    Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
    Zenith Remote controller
    It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
    Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
    Televison & Video Logo
    56 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
