Question about Chase-Durer Conquest Sport Chronograph #779.2SLL Watch for Men
Lost one screw attach to the rubber belt aside watch mechanism
Need to know where to buy the screw in order to re-attach it to the watch.
  • 299 Answers
Any watchmaker or jeweler should have what you need.
Posted on Apr 27, 2010
The word (op en) on the top in place of the date or the day and nothing is responding
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Feb 27, 2011 | Casio Protrek Triple Sensor PRG70 1BVDR...
Need new watch strap rubber and metal , where can I order it from
mcdevito75 here, Ebay would be your best bet, or a flea market in your area. Or you can look for a small watch repair shop in your area. One thing, you"ll need to know the size of the watch lugs, this is where the strap/band attaches to the watch in milimeters, most rulers have a milimeter scale along with the usuall USA measureing scale, simply count the milimeters between the lugs to get your strap.band size in MM.
Feb 09, 2011 | Watches
INVICTA SUBAQUA NOMA 3 SCREWS LOOSEN I have had five screws fall out of my watch in the last 9 months. Initially they fell out 3 months after purchase. Conveniently outside of the 30 day return policy. At...
I have an invicta subaqua noma 3 model no.0736 that I am trying to replace the bracelet/band and would like to know how to change it , how many screws do I remove and what screws do I remove, can you help me?
Dec 21, 2010 | Invicta Subaqua Noma Iii S
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do I replace the rubber watch band?
    Get the screwdriver and start to unscrew all the screws relating to band and rubber casing. Then undo springbars. Then unscrew caseback screws, take out the rubber gasket, unscrew the battery contact screws and take out the battery. Buy exactly the same one and replace it, then do all the operations in the same way other way round. Rate me, please.
    Jun 24, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Ilive in Brazil and I have bought my watch in
    With a magnet if you know the the area. Not trying to be funny here, but maybe you know about where you lost it. If you don't really know, then maybe you get want to know where to order one. If that is the case, then there are places to order one if you know the size. That is, take out one of the other ones and measure it or take it to a place that carries them. If you don't want to do that and you just want to order one, then go "online" and start calling watchmakers for the screw. I am sure you will find one that will help you.
    Dec 14, 2009 | Watches
    Chase-Durer Conquest Sport Chronograph #779.2SLL Watch for Men Logo
    148 people viewed this question
    Top Chase-Durer Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Chase-Durer Watch Expert? Answer questions, earn points and help others
