Question about Homelite Garden
Have a homelite st 285 trimmer. which line from the gas tank makes up to the top of carb?
#1 Taper
  • 1040 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • 850 Answers
SOURCE: have homelite weed trimmer that won't start
recheck carb dighram is located properly! & that its sealed at the mounting of manifold to head!
Posted on Jul 24, 2009
  • 138 Answers
SOURCE: Homelite ST-185 (15039A). Route new fuel line.
If you look closely there should be 2 holes in the fuel tank, also if you look inside the fuel tank there should be some remaining pieces of the fuel line and a fuel filter. If this has been sitting for any length of time you will also want to replace the fuel filter.
Now comes the fun... or a challenge
To start with you will need 2 sizes of fuel line ( go to a small engine repair shop) while you are replacing things you may want to buy a new primer bulb also.
to insert the fuel lines into the tank you will have to cut a tapered tail about 2 " long so that you can grab the fuel line with a needle nose and pull them through and out of the tank so that you can trim off the tapered tails. On one install the fuel filter and stick back into the tank, on the other trim the tapered tail off and pull the line back into the tank but leave about 1" sticking through the tank.
Now hook up you fuel lines to the carb and/ or primer bulb
Fill tank half full with fuel ... now test the installation if it doesn't pump fuel but instead you can hear it blow bubbles in the tank it is simple just reverse your lines on the carb / primer bulb
Retest if it works like it should you are ready to attempt to start it... good luck
Posted on Sep 09, 2009
  • 40 Answers
SOURCE: what is the gas oil mixture on a homelite st-155 string trimmer?
your trimmer should give yu th fuel ratio somewhere close to where you fill it. It will be in this orat- 50:1 forexample
Posted on Sep 12, 2009
  • 11 Answers
SOURCE: Fuel Lines
Off of the primer bulb there should be two lines, one goes to the tank, the other goes to the carb
Posted on May 05, 2010
Homelite st 285 BBC trimmer. Need a new gas tank.
from e-bay or homelite repair agent spares
Aug 30, 2017 | Homelite Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 09, 2012 | Garden
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite UT2680 trimmer fuel line (25cc engine)
You can go to a small engine repair shop, parts shop or look on eBay and they should have the fuel lines you need. Not very expensive, about $1.00/foot for new Tygon lines. You are way overdue for replacing yours. The ethanol in the gas does a job on them.
Jun 09, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Fuel Lines
May 04, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Sep 08, 2009 | Homelite Garden
Trimmer wont stay running
the top line from the gas tank goes to the front nipple on the carb, the lower line from the gas tank goes to the back nipple on the carb
Sep 06, 2009 | Homelite Mighty Lite Lawn Trimmer
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
192 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
