Programming exaples of string array,character array,data array,creating programand c++
  • Gene Wells May 11, 2010
    Not cetain what it is that you want... but there are plenty of sites on the Web with c++ examples.
    Geno
  • 4,234 Answers
This sounds remarkably like a homework assignment type of question. Any C++ reference book will contain examples of this. Also, look for books about data structures which will contain not only examples of the above, but complete explanations of the concepts and uses of each.
Dan
Posted on Mar 26, 2008
How to write a program to translate english text to binary string and write a program to do inverse 27 = . , 28 = , 29= ? 30 = . 31=
to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
here's some links that might be of interest to you.
Visual FoxPro VFP CTOBIN and BINTOC Functions Equivalent In Net The Most Accurate and Reliable Source Code Converters
Feb 06, 2015 | Microsoft Visual Studio 6 6.0 Professional...
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
Write a pseudocode declaration for a string array initialized with the following strings einstein newton
the nice thing about pseudocode is that there's many ways to do it
E.g 1;
String str = new Array["einstein',"newton"];
E.g 2;
myStringArray = new Array{'einstein','newton'}
BOTH of the above are correct, because they are pseudocode
Oct 19, 2014 | Computers & Internet
How do I divide the word meat into syllables?
Given your list of words, It appears to me that what makes up a syllable is the vowels in the word.. each time 1 or more vowels are separated by 1 or more consonants/symbols, a syllable is born.
so, have an array of characters containing vowels.
now iterate through the given word and create a new syllable(String) by adding the characters you are inspecting until you find a vowel.. now continue to add the vowels you find until you find a consonant/symbol.. that's where your new syllable ends (you can add it to a List if you want or just output it to the command line) ..and if you haven't gone through the entire word yet, create a new syllable(String) and repeat the process.
Good luck
Sep 10, 2014 | Computers & Internet
Write a program that creates a linked list of characters from a string entered by the user. (The string can be initially entered into an array if you wish.) Your program is then to move the second part...
Here's a brute-force C++ program to do it, assuming FixYa doesn't mangle the formatting. The last loop merely outputs the resulting list, since it makes no sense to just do all the work without showing the result.
#include <iomanip>
#include <iostream>
#include <list>
#include <string>
using namespace std;
int main()
int brk, j;
list<char> lst;
string str;
cin >> str;
for (string::const_iterator i(str.begin()); i != str.end(); ++i)
lst.push_back(*i);
cin >> brk;
j = 0;
for (list<char>::iterator i(lst.begin()); j < brk; ++j) {
lst.push_back(*i);
lst.erase(lst.begin(), ++i);
for (list<char>::const_iterator i(lst.begin()); i != lst.end(); ++i)
cout << *i;
cout << endl;
return 0;
Nov 01, 2013 | Televison & Video
What is strings in java?
Handling character strings in Java is supported through two final
classes: Java String and StringBuffer. The String class implements immutable character strings, which are read-only once the string has been created and initialized, whereas the StringBuffer class implements dynamic character strings. All string literals in Java programs, are implemented as instances of String class. Strings in Java are 16-bit Unicode.
Nov 21, 2012 | Sun Java Programming Language (cdj-275)
Define a character array and use strcpy() to copy a string into it. Print the string out by using a loop with a pointer to print out one character at a time. Initialize the pointer to the first element and...
Nice, computer science homework.
int main () { char str[]="this is my string";
//print our string forwards int i = 0; while(str[i]!="\0") { putchar( str[i] ); i++; }
//newline putchar('\n');
//print our string backwards int length = strlen(str); while(length--) { putchar( str[length] ); } }
I didn't test this to make sure it worked, but this is the general way of doing this. It looks like your professor wants you to use pointers. I used pointers here. Do you know how? Arrays are pointers with some syntactic sugar.
I wouldn't rely on sites like this to get answers to your homework. Even if you get the right answer, there's always the possibility of your CS professor finding this answer online and then making your future homework ten times harder.
Mar 01, 2011 | Computers & Internet
Merging two arrays and sort them
NEED A NEW KEY THE ONE ON THE BOX WONT WORK
Jul 29, 2009 | Microsoft Windows XP Professional With...
How to access data from ms access with buffer in class code with vb application
Use ADO and create a connection string for a Jet file (version matters here when creating the string). Then use ADO commands and return recordsets to buffer your data.
Mar 26, 2009 | Microsoft Visual Basic 6.0 for PC
Computers & Internet Logo
150 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
